GU Patrol 12volt out let
Submitted: Sunday, Jul 20, 2008 at 22:34
Member - Vince M (NSW)
One of to 2 std dash 12 volt outlets (left) is no longer working all the fuses are ok but no power to it, I remember someone else having the same problem & it was fused with something strange or wired differently as they are not fused together.
Reply By: palmy - Monday, Jul 21, 2008 at 09:14
I had trouble with one of
mine once, it was the outlet that wasn't the cig lighter (that one is marked on the fuse panel under the dash). It still turned out to be a blown fuse, and was still in the same fuse panel. Problem is it's not marked! It's still a 10amp fuse, and from memory down around the bottom right hand corner of the panel. I could probably check
mine tomorrow night if needed.
Mark
316296
Reply By: Michael ( Moss Vale NSW) - Monday, Jul 21, 2008 at 15:12
Fuse 18 on the under dash panel... headlight washers!! 10amp from memory!! Michael
316331
Reply By: Member - Vince M (NSW) - Tuesday, Jul 22, 2008 at 18:15
Thanks guys but its not the fuses, its just died some where in the loom
regards Vince
316585
Reply By: Member - Mike DID - Tuesday, Jul 22, 2008 at 18:57
Cig Lighter Sockets have fusible links inside them to protect against over heating.
316592
