Toyota Prado
Submitted: Tuesday, Jul 22, 2008 at 20:12
ThreadID: 60050 Views:5965 Replies:12 FollowUps:8
Hi all,
After years of driving Patrols and Landcruisers, I want to down size a notch and would appreciate some comments on Prado : is it more user friendly in town ? Does it cope reasonably offroad? Any marked difference between diesel & petrol ?
With diesel being 15/20 cents more than petrol there seems to be very little cost advantage with diesel. Your comments most welcome, thanks.
Ian
Reply By: toyocrusa - Tuesday, Jul 22, 2008 at 20:41
Hi Ian. I have a 2004 GXL petrol model with the first of the 5 speed auto which is still fitted to the current model. I have covered 55000Klm and found it to be a perfect all round vehicle. We downsized from a 100 series petrol/gas(98 model) and although not as much room inside as the 100 series still find the Prado brilliant as an all round vehicle. Good turning circle,easy to park. great towing torque, tows a 2 tonne boat comfortably with around 17/18 ltr per 100K fuel consumption. Good ride and handling, reasonable for the wife to drive (we are both 63yrs old) averages 15ltrs per 100K around town and have had 11ltrs per 100k on a trip. 180ltr fuel capacity gave us 1400Klms to queensland one trip with 15ltrs left so incredible touring vehicle. Easy to service if you are mechanically minded(I am,Lucky I guess) with 10000K service intervals. What more can I say. It has been a totally reliable, well designed and made vehicle. Insurance around $600 per annum. Tyres recently at $222.00 each. Basic services at a dealer $170 so for a decent size car I think it is reasonably economical as well. Hope that is a bit of help.Bob
AnswerID: 316632
Reply By: Member - Phil G (SA) - Tuesday, Jul 22, 2008 at 21:11
Thousands of soccer mums can't be wrong :-))
But seriously, they are very common in our 4wd club, for good reason. All the Prados were pretty good offroad - lighter vehicles with plenty of power. The 90series had better ground clearance, but with the usual 40mm lift, the 120series go everywhere the others go. Around town, they are easier to park and have a tighter turning circle than the bigger LandCruisers, with good visibility over the bonnet.
The diesel 1KZ-TE is not as economical as most would like.Mine used to give 12-13 l/100k doing the same trips with V6's that would get 14-15 l/100k. But if you're buying new, the later D4-D 1KD-FTV motor is a lot more economical, and IMO is the choice of the current motors.
AnswerID: 316639
Reply By: Member - Madfisher - Tuesday, Jul 22, 2008 at 21:17
We have two at work, they are a great vehicle and stay reliable till well past 300000ks. The only issue I have is I find the suspension bias is towards a very good ride rather then handling. On long straight highways they are very relaxing to drive, but on winding black top they feel a bit like a yank tank. But that is pressing on a bit with the boss paying for the fuel. lol That would be easy to fix with stiffer shocks, and springs.
Cheers Pete
AnswerID: 316645
Reply By: Kim and Damn Dog - Tuesday, Jul 22, 2008 at 21:20
Ian
I'm on my second one now (current model). The first was a manual, and the current car is an Auto (both petrol). The only problem I've had is with the fuel sensor, which will be fixed on Thursday.
My only issue with the design of the car (and I've said this before) are the plastic surrounds at the back end. I've had to replace them three times now, and it ain't cheap. If your thinking about buying one I recommend a kaymar rear bar.
The first car copped a bashing whilst shooting, and spent a fair bit of time doing cross country work. It never let me down once. Their also a very comfortable touring car.
Finally, before you buy, have a look at the engine compartment. Don't know much about the new Prado diesel, but a mate of mine purchased a Nissan Navaro some time back and didn't have enough room to install a Chop Stick, let alone a second battery. LOL
Kim
AnswerID: 316648
Reply By: altim - Tuesday, Jul 22, 2008 at 22:39
I have an 07 GU and an 07 Prado for a work vehicle. The Prado is averaging 450k's a day with half of that on gravel and powerline tracks. Not sure about economy but can't fault it otherwise.
Al.
AnswerID: 316671
Reply By: Robin Miller - Wednesday, Jul 23, 2008 at 08:47
Hi Ian
Its a subject I have thought about a bit myself and on my short list of replacements for my Patrol (along with gas conversion - whilst secretly hoping Nissan will come out with a new patrol diesel engine).
No doubt its a well built capable 4wd, and touring range is magic.
I haven't yet been able to find a work around for its stability issues. (rollover potential)
It was certainly improved with increased track width a few years ago but is still to far short of the Patrol for me.
Its probably acceptable to most if going for one with stability control and by not raising it or loading any weight onto the roof.
Amongst the models I also like the look of the 6 speed manual diesel now available as a long term low cost tourer.
AnswerID: 316706
Follow Up By: Tenpounder - Wednesday, Jul 23, 2008 at 10:06
Hi Robin Miller. I am interested in info you have unearthed as to the stability of the Prado. It doesn't surprise me to hear that it not stack up against, say, the Patrol, espeially for lateral stability.
My point is that, yes, I own a 90 series Prado (GXL model, so a bit wider, perhaps, than the base model), and yes, it has a 2" lift, and, yes, it has an aluminium roof rack. So how 'bad' it my vehicle? I am NOT about to have a go at you, but keen to draw on your knowledge.
Any commets? thanks.
FollowupID: 582972
Follow Up By: Robin Miller - Wednesday, Jul 23, 2008 at 11:41
Hi TenPounder
On a day when our news broadcast have said the government is considering mandatory electronic stability be fitted to cars its sobering to review rollover stats in 4wds.
Rollover stability is a massive poorly reported issue in this field
and its a little disconcerting that no figures tilt table are pubished to my knowledge on the 120 series, espically by Toyota.
I think some 50% of deaths in american SUV's are now from rollovers.
Toyota have a figure of 45 degrees on the 100 series Cruiser and Nissan 48 degrees on the patrol , not near my library at the moment but I think its about 43 for your 90 series
from RACV tests (They no longer do tilt table tests).
I first got concerned, must be a decade ago at the launch when I test drove one at Angelsea proving grounds, which included a side slope test.
She's a high and narrow car but since then the track width has increased a bit from I think from 1505/1510 to 1575/1575 with the new model.
Its worth pointing out that while in the lower end of rollover performance they can be a good viable car for many if not pushed, and I admit I mostly drive in victoria with lots of big and steep muddy hills.
I'd look at keeping your front shocks in top order, stacking the weight down low and in front of the rear axle, and perhaps removing the lift and adding more underbody protection to compensate.
I note that rear wheel spacers are a hot selling item for the new troppy type cruisers , but I think if fitted to a Prado that the wheels would hit the guards, and this makes it hard to do anything fundamental to improve the car.
FollowupID: 582987
Follow Up By: Tenpounder - Wednesday, Jul 23, 2008 at 14:58
Thank you, Robin Miller for your comments. It is perhaps food for thought that I have made things worse in terms of static roll angles by adding stiffer (as well as longer) springs, but this may have improved the dynamic lateral stability (less lurch).
It is an issue for all of us that a bit of soft stuff on the downhill side (eg topping a dune in the Simpson and turning sharp right as one has to) could easily cause problems when there's a bit of weight on the roof rack.
Thanks again for your contribution to our understanding.
FollowupID: 583009
Follow Up By: Ken - Wednesday, Jul 23, 2008 at 18:55
Robin [and others] you need to be careful quoting 45 degree and higher rollover figures. In many cases the manufacturers spec actually says 45%. This is 45% of 45 degree or 1 in 1.
When you consider a 45 degree angle you will see that very few vehicles could ever remain upright on this slope. To my knowledge the only vehicle that could remain upright on 45 degrees was a series 1 Landy. I say a pic once of the Rover factory test with a series 1 shorty soft top sitting on a steel plate. There is no way known any modern wagon would remain upright on a 45 degree slope.
Ken
FollowupID: 583057
Follow Up By: Robin Miller - Wednesday, Jul 23, 2008 at 19:36
Hi Ken
No problems , I'm well up on the engineering side of things in these matters.
It is 45 degrees not 45% and the 100 series landcruiser brochure I have in front of me here even has it in a little picture form in degrees.
The RACV tests used the seymour military faciliy and completely document the process.
FollowupID: 583067
Follow Up By: Ken - Wednesday, Jul 23, 2008 at 22:13
Robin, simple physics says once the centre of gravity falls outside the object envelope it must fall. This is because the vertically acting component of the vehicle mass is greater than the horizontal component. If you look at an object on a 45 degree slope, take the simple case of a square box. Put a dot in the centre of the box representing the centre of gravity of the object, draw horizontal and vertical lines to the slope; you will find they are of equal length. Now put the dot a few mm above the centre of the object and see the difference in the length of the lines and where the vertical line meets the slope. It is outside the envelope of the object and longer then the horizontal line. The lines represent the forces acting in the vertical & horizontal planes, the force down is larger than the force horizontally so the object tips.
A Toyota brochure [or any other vehicle manufacturer's] is hardly a scientific or engineering document and I remain unconvinced that a 100 series would a) not slide off , or b) not tip on a genuine 45 degree slope.
Ken
FollowupID: 583122
Follow Up By: Robin Miller - Thursday, Jul 24, 2008 at 09:37
Hi Ken
Your reply introduced a different point "Slipping".
Slipping sideways is not part of the tilt table test as this depends on the co-efficent of friction between the tyres and ground - on ice every car slips sideways at even a few degrees.
In actual fact almost every standard car like commodores and falcons exceeds 45 degrees its only the 4wds that don't generally make it and average out at 40-45.
The following link may convince you.
It shows tilt angles for vehicles modified for police work , yet even
with the extra gear the cruiser comes in at 42.2 degrees, and further reading of this Monash university report shows that Nissan Patrols are a lot better, and troppies as a disaster.
http://www.monash.edu.au/cemo/roadsafety/abstracts_and_papers/054/roadsafety%20conf%20police%20paper_revised.pdf
Unlike the square box you described which has an even density distribution a vehicles roll point is expressed by its Static Stability factor. (track width/ 2 * C of G).
These figures are required by law in USA and are publically available, and are almost all above 1.
FollowupID: 583187
Reply By: deserter - Wednesday, Jul 23, 2008 at 09:28
I have an 07 D4D. I just love the car. Its been to the Tip and did the trip up the OTL with ease. I get 10k per litre round town. It tows my 2T van as though it isn't there - though the consumption drops to 6k per litre.
AnswerID: 316711
Reply By: Member - Rodney B- Wednesday, Jul 23, 2008 at 09:30
Have 2 friends with current Prados and I am now a convert. On a recent club trip the Prado out performed my 80 series on a steep climb (He drove and I had to winch) I think the weight difference was significant and while I had more clearance the Prado still got through all the deep rutted bog holes with ease.
Fuel economy is good in the new diesel with figures of 1500kms a tank (2 X 90 ltrs) being quoted (one owner said he got 2000 out of one trip) (highway long distance).
I don't know how I will fit all my gear in a Prado but I guess I carry too much anyway.
AnswerID: 316712
Reply By: Member - Philip S (SA) - Wednesday, Jul 23, 2008 at 19:08
Ian,
Very happy with my Prado GLX TD auto (see profile), now done about 75k. including some fairly serious off road work. I added a D-Tronic chip when I bought the car and it makes a very significant and noticeable difference to power and torque and does not seem to affect fuel consumption that much, long term average is 12.37 litres/100.
The 180 litre fuel capacity is an absolute boon.
Don't know whether you plan to tow anything, but be aware that max is 2500kg, against 'Cruiser 3500kg.
The Prado is exceptionally comfortable for long trips. My wife has a little Alfa 147 which we recently took from SA to NSW and back and it was a literal pain in the arse for me. Since then we have made 2 rushed trips to and from Melbourne in the Prado, and both agree it's the most comfortable long trip car we have ever had.
Cheers, Phil
AnswerID: 316802
Reply By: Ianwa - Thursday, Jul 24, 2008 at 15:49
Thanks Phil,
I have also often found that I am more comfortable in the "sit up"
position of a good 4W on long trips.
What is the D Tronic chip and what exactly does it do ?
Best wishes, Ian
AnswerID: 316938
Follow Up By: Member - Philip S (SA) - Thursday, Jul 24, 2008 at 18:30
Ian
Lokk at this. http://www.safarisnorkel.com/dtronic/dtronic.htm
They are available and fitted by ARB among others.
FollowupID: 583303
Reply By: DOBBO60 - Thursday, Jul 24, 2008 at 21:25
Hi IANWA,
check out www.pradopoint.com, there is a wealth of information to be found on every aspect of the vehicle.
I have had my V6 GXL for 2 years now and have driven almost 70,000kms in it and would rate it as the best car that I have owned.
AnswerID: 317023
Reply By: roblin - Friday, Jul 25, 2008 at 15:46
I have a 2004 1KZTE TD Prado. Fantastic vehicle although the old TD is a bit under done. A D-tronic chip helped a lot by removing the fuel lag (refer LCOOL for this one) below 1800 RPM.
Before considering the D4D, you may want to have a read of a long psot on Pradopoint regarding issues with the new motor. It appears there may be an injector problem at the moment and it is causing a number of concerns after the vehicles have done about 10 000kms. I was considering a new D4D but will satisfy myself with the old TD until the Prado D4D proves itself. It appears that the increased power delivered from the Pardo common rail TD is causing some issues.
Don't discount the V6 Prado either. For a petrol, they are reasonable economical and quite powerful. With the huge difference between diesel and petrol costs these days the petrol is very viable. Also LPG conversion then becomes a consideration.
Apart from this, the vehicle is a great all round performer. Great in the 'burbs and in the bush. Yes the rear end plastics can be an issue and there is a lovely blind spot over your left shoulder (rear camera fixes this). Having owned a Patrol before this vehicle, their is no comparison in ride day-to-day. If like me, you need the extra seats on occasion, they are quick and easy to remove/replace therefore giving some added flexibility in design as opposed to other designs where the seats are bolted in.
Rob
AnswerID: 317170
