Diesel to LPG Conversion??
Submitted: Wednesday, Jul 23, 2008 at 21:25
Bekali
Good evening everyone, I currently own a 1995 3500 pajero but it's time to upgrade the old girl. I am looking at a Manual VRX 2007/8. I have found a petrol one and a diesel one. The diesel is a better buy.....
My question is 'Does anyone know if a diesel engine can be converted to LPG?'
Many thanks
Bek
Reply By: Member - Roachie (SA) - Wednesday, Jul 23, 2008 at 21:42
You can add LPG fumigation to the diesel. It means that your engine uses LPG as
well as diesel, both at the same time. You can still run the motor on straight diesel BUT you cannot run the motor on straight LPG.
The LPG increases the power output of the motor as it means that you are getting a more complete burn of the diesel your engine is passing through.
In a non-LPG diesel, a larger proportion of the diesel goes through, unburnt and is wasted.
So, with LPG added to a diesel you get more power PLUS better fuel economy.
Roachie
316844
Follow Up By: Bekali - Wednesday, Jul 23, 2008 at 21:44
How do I do this??
583111
Follow Up By: Member - Porl - Wednesday, Jul 23, 2008 at 22:09
Bekall
Google "Diesel to LPG" or "Diesel to gas" using the Australia search and you'll get bucket loads, or even search this
forum "diesel gas", lots of posts.
583115
Follow Up By: Member - Roachie (SA) - Wednesday, Jul 23, 2008 at 22:12
one example is
www.eco-gas.com.au
there are numerous others too.
583117
one example is
www.eco-gas.com.au
583118
one example is
www.eco-gas.com.au
583119
one example is
www.eco-gas.com.au
583120
Follow Up By: Member - Roachie (SA) - Wednesday, Jul 23, 2008 at 22:13
one example is
www.eco-gas.com.au
583121
one example is
www.eco-gas.com.au
583123
Follow Up By: Twinkles - Thursday, Jul 24, 2008 at 07:34
You starting to stutter Roachie.
I have EcoShot on my Hilux. Lucy has it on his Troopy.
583147
Reply By: sleepy1 - Thursday, Jul 24, 2008 at 09:10
i run the gas system on my mu about 5 years ago ,( got it sent out from America ) and worked fantastic, i got a further 100 ks out of it. and about 10 % more power.
316884
Reply By: EscapeArtists - Thursday, Jul 24, 2008 at 09:37
Hi all,
Ive heard that mixing LPG with diesel in a non turbo engine is hardly beneficial at all... is this true?
316891
Follow Up By: Twinkles - Thursday, Jul 24, 2008 at 19:55
EcoShot runs from the turbo boost.
583333
