Question to Derek
Submitted: Saturday, Jul 26, 2008 at 09:28
ThreadID: 60157 Views:2265 Replies:5 FollowUps:1
Derek
I'm using a simple dual battery setup, 2 lead acid 96ah with a manual switch on the Aux battery to isolate it.
When both batteries are joined together can I use my smart charger to charge both together IE leave them connected and charge the main. If so there are two settings on the smart charger one under 100 ah and the other over 100 ah. At the moment I charge them individualy. How does the charger look at the connected batteries. As a large 96ah or as 192ah ???
Reply By: DIO - Saturday, Jul 26, 2008 at 10:00
Why not contact him direct, for a speedier answer Link
AnswerID: 317289
Reply By: Vivid Adventures - Saturday, Jul 26, 2008 at 10:15
Just to get up DIO's nose... I'll answer what I know.
You will be charging both batteries when they are connected.
The charger is just putting out (say) 12A and this will charge both batteries at relative rates depending on their ability to accept charge.
I'd guess the switch on the charger is to provide a higher Amp output (say 6A for 100 Ah) which is rather arbitrary anyway. Look at the documentation for the charger.
Generally speaking, however, there are a few traps to charging them together if they are not being used together - the smart charger switches to trickle mode based on voltage, for instance, and if one of those batteries comes up faster, the other battery may be under-done.
AnswerID: 317290
Reply By: Member - Rodney B- Saturday, Jul 26, 2008 at 10:26
Thanks for that Vivid, I posted to Derek because he generally answers so that you can understand but you have given me what I wanted. No literature on my charger so can't consult it and I thought there may ba a few others interested in the answer.
Cheers Rod
AnswerID: 317294
Follow Up By: Affordable Batteries & Radiators - Saturday, Jul 26, 2008 at 11:33
Hi Rodney
Andrew has it basically covered.
It is an interesting charger that allows you to choose battery capacity. I would like to know more bout the charger before deciding exactly what to use so you don't damage the batteries.
If charging them together it would be best to set the charger to the higher setting and connect to the auxiliary battery as that would be the one with the lowest charge. If your cables are good and thick then the charger will see it as one battery.
If one battery gets hot or the charger does not enter float mode charge them one at a time and have the faulty battery tested. (The one that does not float or gets hot)
Derek.
FollowupID: 583603
Reply By: Member - Phil G (SA) - Sunday, Jul 27, 2008 at 09:31
Rodney,
I know your question is well answered.
I run the same as you under the bonnet - 2 identical batteries connected by a marine switch.Mine stay connected all the time - so they start together, charge together, and for one night stays they run the fridge together (longer stays I isolate them). I like it because its simple, and each battery is required to do less work. Downside is that if one battery drops a cell, the other one will get pulled down.
When hooking them up to a 240V charger, I hook the charger into one of my power outlets in the cab.
I do also run a 3rd battery (AGM) in the canopy, but that is isolated with a fancy isolator.
phil
AnswerID: 317437
Reply By: Member - Rodney B- Sunday, Jul 27, 2008 at 09:59
Thanks Phil and Derek for your answers .
The battery charger is a PowerTek Plus 4 stage charger (purchased from Jaycar) and gives the abilty to select 25 to 100 or 100 to 200 AH and works very well.
Like Phil I also have the CT with a smaller battery that charges via Anderson Plug from the Main and have been operating this setup for about 2 1/2 years with no problems.
I run two identical Batteries in the Cruiser with a H/D isolator and only run the engel off the Aux overnight or long stays.
So far I have never had a flat battery and I keep the Multi meter handy and use the Honda if the voltage drops on the Aux.
The alternator seems to cope with the 3 batteries OK.
AnswerID: 317441
