wheelchair accessible off road pop top
Submitted: Saturday, Jul 26, 2008 at 14:34
ThreadID: 60167 Views:2561 Replies:5 FollowUps:7
hi guys i,m new to this so bare with me. Me misses is in a wheelchair and i am thinking about either modifying or building an offroad pop top to suit.
problem is with off road your probably 500-600mm to main floor level. my idea for solution is air bags on trail arm indepent suspension with shockers But that only raises or lowers van bout 100mm untill bump stop hits under chassis. would like to get floor down to 250-300 mm when parked.
Anyone got any ideas??????
Reply By: nomadoz - Saturday, Jul 26, 2008 at 15:06
Hi psm won’t it be a lot easier and cheaper to make an aluminium ramp and then when not in use store it under nit the Van or vertical on the back of the van,
Just my 2 bob
AnswerID: 317325
Follow Up By: psm - Saturday, Jul 26, 2008 at 15:25
thanks for your reply . Ive looked at that but offroad vans are still 500 min off the ground and to make an accessable ramp work @ 500 high it would have to be 7 metres long. me misses wants to be able to use the ramp ect indepently. thanks anyway.
FollowupID: 583628
Reply By: Member -Dodger - Saturday, Jul 26, 2008 at 15:24
There is an Australian maker that makes caravans for the disabled.
It is called the Accessavan Made by Roadstar.
Accessavan
andHere
If nothing else it will give you food for thought.
Cheers Dodg.
AnswerID: 317329
Follow Up By: psm - Saturday, Jul 26, 2008 at 15:27
thanks dodger, i have been talking to anthony from accessavan but at this stage the $$ is slightly out reach for us. cheers
FollowupID: 583629
Follow Up By: Member - Graham H (QLD) - Friday, Aug 08, 2008 at 15:14
THere is a full writeup in the August edition of Caravan World
FollowupID: 586386
Reply By: ruafrood - Saturday, Jul 26, 2008 at 15:26
Roadstar make a wheelchair accessible caravan.
Not cheap but may give you some ideas.
Site Link
http://www.accessavan.com.au/
Ron Dickson
AnswerID: 317330
Follow Up By: psm - Saturday, Jul 26, 2008 at 15:30
Love the accessavan but i dont think they make an offroad yet
FollowupID: 583633
Reply By: Member - kevin Y (SA) - Saturday, Jul 26, 2008 at 15:27
had a platform on back of van ---ramp dropped down sideways so as i could drive on electric scooter----also a ramp going up to entrance doorway
hope that helps ----my wife had emphasemia
AnswerID: 317331
Follow Up By: psm - Saturday, Jul 26, 2008 at 15:29
thanks kevin if you have any pics would love to see them. paul
FollowupID: 583631
Follow Up By: Member - kevin Y (SA) - Saturday, Jul 26, 2008 at 15:30
i made the ramps etc myself
FollowupID: 583634
Follow Up By: Member - kevin Y (SA) - Saturday, Jul 26, 2008 at 15:47
the van i used it on was an old type with chassis ---i etended the chassis out the rear put a chequer plate across -- the ramp was long enough to reach the ground and it swung up and down on a steel rod the bottom
sorry i havent got any pics
when i bought a toyota coaster i put it on that
FollowupID: 583635
Reply By: Oldsquizzy (Kununurra) - Saturday, Jul 26, 2008 at 15:40
There are ways around what you want. Depends how handy you are. You can make a lifter using 12 volt hydraulics very similar to a tail gate lift on a small truck.
Used to make them for disabled buses and such that took you from the floor of a coaster bus to the footpath.
In you case instead of a slide away you could use a fold up at the rear of the van and a simple lift and lower arraignment using magnetic micro switches to limit raise and lower heights, change over relays will allow to raise when lower is tripped and vice versa.
Steel frame and aluminium plates will lower weight of assembly.
AnswerID: 317332
