Water tank lock
Submitted: Monday, Jul 28, 2008 at 14:15
judyu
Can someone help with a problem on our new caravan.
The
water tanks have the locking lid which is supposed to spin freely once they are locked, but I can't seem to get
mine to do this - they can be removed whichever way I turn the key! How are they supposed to work?
Reply By: Member - len W SWANSEA (NSW) - Monday, Jul 28, 2008 at 14:39
judyu try turning the key to lock then pull the key out it out it should spin then
hope this helps ................ len
317669
Reply By: Member - keith P (VIC) - Monday, Jul 28, 2008 at 19:35
sounds like the cap is faulty i have this problem when they get full of dust ands after a clean they come good, but if its new then take it back to the manufacturer.
317726
Reply By: The Rambler( W.A.) - Monday, Jul 28, 2008 at 20:51
Judya,
Hold the cap stationary while turning the key then remove the key once it is locked.Some caps tend to turn while you are trying to lock it which results in an unlocked cap after removing the key--hope this helps.
317743
