1977 FJ40 Tailshafts
Submitted: Monday, Jul 28, 2008 at 14:45
ThreadID: 60244 Views:2266 Replies:3 FollowUps:4
Hey guys, Ive got a 1977 FJ40 that Im working on and I changed the front diff to disc brakes. I installed the motor and gearbox and when I tried to add the front tailshaft I noticed that its 100mm to short.
Is there a difference in the diff sizes between a drum brake diff and disc brake diff?
any help would be great.
mat
Reply By: Member - Tour Boy Springsure- Monday, Jul 28, 2008 at 18:17
Hi Mat,
This may be a silly question but you did put the longer tailshaft on the front and the short one on the back?
The diffs as far as I remember are the same unless somone did a bodgy job on it sometime in the past.
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 317704
Follow Up By: 1977FJ40 - Monday, Jul 28, 2008 at 18:20
Hi Dave, yes the short tailshaft is at the back and the longer one at the front.
thanks
FollowupID: 584045
Reply By: Peter 2 - Monday, Jul 28, 2008 at 19:16
What did the disc brake front diff housing come off ?
From 1990 on everything had a small front diff centre.
AnswerID: 317720
Reply By: donk - Monday, Jul 28, 2008 at 23:20
I don't suppose you have had the front springs out & put them back in the wrong way around & the front axle housing is sitting to far forward (i have seen this before)
Regards Don
AnswerID: 317788
Follow Up By: 1977FJ40 - Tuesday, Jul 29, 2008 at 00:07
Hi Don, thanks for the info so I can double check what ive done is the short side of the springs supposed to be facing inwards or outwards??
FollowupID: 584138
Follow Up By: ross - Tuesday, Jul 29, 2008 at 10:50
I would have thought the short side of the spring goes to the rear (if thats what you mean by inwards)
I say that because ,usually the competion rock climber guys turn their springs around for a longer wheelbase.
I wouldnt have thought it would shift the axle forward by 100mm though.
More like 30-40mm
FollowupID: 584181
Follow Up By: 1977FJ40 - Tuesday, Jul 29, 2008 at 17:09
Hi Ross,
Thanks that was the problem I had the springs around the opposite way. The short side of the spring was facing towards the front bumper instead of the rear.
thanks for all the help.
FollowupID: 584281
