Primus Hot Water Unit
Submitted: Tuesday, Jul 29, 2008 at 10:29
Member - Paul Mac (VIC)
G'day folks. Just a quick question in relation to a primus hot
water unit I purchased a few months ago for the camper trailer.
I finally decided to take it out of the C/T last night and see how it works. Hooked up the gas, filled a bucket of
water and had another bucket to run the shower head into while warming up the
water through the unit, hooked up the 12v to a portable battery unit I have and lit te pilot light. I did everything the instructions told me to do. Held in the ignitor button for the 20 seconds they say until
the pilot light remains on whilst the unit is running the
water then I turned up the control button to 'hot' .
After about a minute of operating the unit on hot it just cuts out and takes
the pilot light out with it also.
Is this what the unit does or does it sound faulty ?
Surely you wouldn't have to keep lighting the thing every minute or so?
Had plenty of
water in the bucket so it wasn't
water being the problem.
Any feedback would be appreciated as I will take it back to where I purchased it if its faulty.
Thanks for your help.
Cheers.
Reply By: Member Brian (Gold Coast) - Tuesday, Jul 29, 2008 at 10:38
Hi Paul,
We owned one of those Primus units until recently, they are quite fiddly and not automatic at all. When they either reach temperature or overheat in the boiler, it will turn off, and
the pilot light goes off as
well. So if the
water isn't warm enough, you have to manually start it again. Heating a bucket of
water was my prefered method as
well, and I found that if the outlet was too close or even just pointing at the pump inlet, the boiler would overheat.
Eventually, after 2 years of frustration, i gave in to SWMBO and upgraded to a Coleman. Fully automatic and is self driving. In other words, with the Coleman, for my wife and kids to shower, i had to operate the Primus for them, as they couldn't grasp the idea. The Coleman we set up outside the shower tent and next to a small window. Whoever is showering simply reaches through the small window and switches it on and voila!!!!! Instant how
water.
I know this probably doesn't help your original questions, but IMO the Primus units do require re-igniting often, and that's why we upgraded.
Brian
317825
Reply By: Member - Dick (Int) - Tuesday, Jul 29, 2008 at 10:49
I have a Primus Hot
Water System and found the biggest problem was the plastic hoses they used which tend to kink and restrict the
water flow. When the
water flow is not sufficient, the temp rises and it turns itself off as a safety measure.
We replaced the hoses with good quality hose and have had no problems since. It can be tricky to get
the pilot light to ignite, you need to be looking through the side window to see if it has ignited.
We removed the flimsy doors on each end of it as you can't pack the larger hose in there anyway.
317826
Reply By: Outa Bounds - Tuesday, Jul 29, 2008 at 12:29
If you purchased yours around Dec/jan then you might have a faulty one, I believe there was a recall.
We got ours in Jan / Feb, we're living in a shed whilst building a house, so needed a shower system and that seemed like the best set up without buying a proper hot
water unit.
Anyway we did find it a bit of a pain to use, like you say it was hard to light - pilot light wouldn't stay on, had to hold it on for ages before we could turn it on properly and eventually it started cutting out and not lighting properly. The ARB store where we got it from changed it out and ever since the 2nd one has been running like a dream! Much easier to light up and it stays on, so in hindsight I could see that there was something wrong with the first from day dot. At the time of the exchange I thought there was something wrong with teh safety switch inside it - the one that kicks in and lets you light it once it knows that
water is flowing, just sounded like it was kicking in and out all the time.
Sorry for the long ramble on above. It certainly sounds faulty to me and I'd take it back to exchange if I were you. I was in a
camping store a few weeks ago and had a chat to the staff there, I mentioned the shower units worked really
well considering ours gets used every night, and I mentioned we had to take the first one back, the lady then told me there had been a recall on some that were sold aorund December.
Reading threads here on Exploreoz on this very topic, I ended up going to bunnings and buying one of those weed sprayers as a back up, just in case the Primus ever does pack it in on us at the crucial moment! Although must say I'm pretty sure it will do the distance for us now.
Do a search on "weed sprayer" and it should bring up some threads on the very innovative idea for a very simple and cheap
camp shower unit! We'll if you're happy boiling some
water for the job.
317857
Reply By: Wizard1 - Tuesday, Jul 29, 2008 at 12:44
Glad we have a Coleman, just turn
the knob it ignites and cycles the gas on/off as required, complete no brainer. Mind you we had some problems with out first one that got replaced under warranty when I went to check it one day and the gas wouldn't ignite. New one is fine.
Couldn't think of any thing more annoying than having your shower interrupted, cold and wet tryng to get
the pilot light back on.
Alwas wondered how good these units were.
317865
Reply By: Member - Paul Mac (VIC) - Tuesday, Jul 29, 2008 at 13:45
I want to thank you guys for your responses. After reading the replies I went back out and set the unit up again only this time I spread the hoses out and as far away from the unit as they would permit.
You wont believe the result.
The damn thing worked !
It warmed up the
water and didn't stop operating at all.
Obviously it can be very temperamental unless it is set up correctly so thank you for al your help.
Much appreciated.
Cheers.
317877
