What gauge fencing wire.
Submitted: Tuesday, Jul 29, 2008 at 12:38
troopyman
What gauge fencing wire should i carry in my tool kit 12g , 10g , 8g . cheers .
Reply By: Member -Signman - Tuesday, Jul 29, 2008 at 12:43
#8
317864
Follow Up By: troopyman - Tuesday, Jul 29, 2008 at 12:47
Hmmm , that is as thick as tent pegs . I dont think i would be strong enough to bend it LOL .
584214
Reply By: Member - Peter G (NSW) - Tuesday, Jul 29, 2008 at 12:52
Depends on what size fence you aim to fix
317866
Follow Up By: troopyman - Tuesday, Jul 29, 2008 at 12:56
Oh man , dont you know i own a troopy and its overloaded . It must weigh close to 10 tonnes by now and something will break soon , i know it . I cannot weld so tying things up with fencing wire when it breaks is my only option .
584221
Reply By: Member - kevin Y (SA) - Tuesday, Jul 29, 2008 at 13:17
take a few metres of the lot ---but don't forget the twitch stick
years back i saw an FJ HOLDEN ----whose floor pan had rusted away ---it had a branch of mulga tied across one side to the other with wire and the
seat wired down to that.
that was in
Hawker S A
317872
Reply By: Member - Oldbaz. NSW. - Tuesday, Jul 29, 2008 at 14:00
As an old fencer & wirer upper, I'd say 10g is plenty good enough
to hold a troopy together. I would go for the older softer style if
you can get it. The newer high tensile stuff snaps easily when
twitched. I would also carry some good lighter tie wire for smaller
jobs, dont know the gauge but at least half a mm thick.....oldbaz.
317882
Reply By: Stu & "Bob" - Tuesday, Jul 29, 2008 at 14:05
I would carry 10 guage or 3.25mm.
Should be enough for most needs.
317883
Reply By: Member - DAZA (QLD) - Tuesday, Jul 29, 2008 at 15:02
Hi All
I have used the Electrical Conduit Galvanised Pull Through Wire,
you can get it in 40 Metre Rolls, just unroll enough to inter- twine it
to the length you require you can use several strands, its easy to
wrap around things and twitch, I used it once for an emergency
when the Trailer Spring Bolt Snapped, it done the job ok.
Daza
317887
Reply By: Member - Kiwi Kia - Tuesday, Jul 29, 2008 at 15:16
I carry some soft iron wire as used for tieing concrete boxing or steel mesh and reinforcing steel. This wire can be twisted before breaking unlike fenceing wire.
317891
Reply By: Member - Ruth D (QLD) - Tuesday, Jul 29, 2008 at 16:08
I'm a girl - I like No. 8 - find that I can Cobb & Co pretty much anything with No. 8.
317899
Follow Up By: Member - kevin Y (SA) - Tuesday, Jul 29, 2008 at 16:13
yeah! my gran used to sit in front of the fire knitting wire netting using no 8s ------------ fair dinkum
584264
Follow Up By: Member - Ruth D (QLD) - Wednesday, Jul 30, 2008 at 11:29
....and I suppose she had barbed wire for hair, as
584485
Reply By: Member - 'Lucy' - Tuesday, Jul 29, 2008 at 17:01
This a real easy one to answer.
8g as the only thing you will ever have to fix is the broken down Nissans that you come across.
On second thoughts, you better chuck in a length of 10g to 'splint up' missan-nissan's owner/driver who will have done himself a damage either by attempting suicide or by coming 'unglued'.
Then again a tad of 12g wouldn't go astray either - especially to sew up the 'missan-nissan' broken/bogged 'chev-issan' owners mouth, to save your ears from 'excuse dribble/drivel' that would be emanating from same.
Yep! just take the lot and you will be safe.
317905
Follow Up By: Member - Roachie (SA) - Wednesday, Jul 30, 2008 at 21:40
hahahahahaha
Toymota owners have LOTS of experience with wire to tie up their ailing rigs with.
Trying to blame this fact on Nissan owners is a dead-set cop-out!
It's a bit like me saying that I only bought a winch for my Patrol so that I could pull Pesty's smoky ol' 60 series outa bogs etc. Nuffin could be further from the truth.....if he gets bogged I'll just leave him there to fill in the hole in the ground.,....
584642
Reply By: Member - Mfewster(SA) - Tuesday, Jul 29, 2008 at 18:33
Now if you are into fencing wire for fixing things, you should check out the Clamp-It. Very nifty little tool. You make a loop of wire and the clamp it draws it in very tight and ties it off. You can make a whole lot of loops for big jobs. I've seen snapped axe handles; broken
suspension shackle springs; snapped bars on roofracks joined with this technique. With one in yout tool box and some wire you don't need to carry a whole lot of different sized circular hose clamps any more either. Also great for making waterproof seals on plastic irrigation systems
317929
Follow Up By: troopyman - Tuesday, Jul 29, 2008 at 20:45
at last a true believer of the virtues of fencing wire . thanks for the tool tip .
584371
Follow Up By: Kev - Member - Wynnum - Wednesday, Jul 30, 2008 at 21:06
Any idea where, on the net, I might be able to view this tool
Thanks Kev
584628
Follow Up By: Member - Mfewster(SA) - Wednesday, Jul 30, 2008 at 21:14
Hi Kev
Try this
http://www.practool.com/clamp-it-tool1.html
The gadget has been improved a little since the model I have. Two sizes available. I have the small one. It takes a little practice to get used to using it, but once you get the knack, it's fine. Some wire gauges seem easier to use than others.
584632
Reply By: Danny & June - Wednesday, Jul 30, 2008 at 22:46
Coat hangers work very
Danny
Broken GQ
318239
