GME TX3220 vs UNIDEN HF088
Submitted: Tuesday, Jul 29, 2008 at 19:03
Member - Serg (VIC)
I have Uniden mounted in my truck. I been given (for free – without any question best value for money!) GME unit and I like it more then Uniden. Would you bother to swap them in my situation? Would I gain anything from such exchange? I would do it without any thinking if not one apparently big BUT. Uniden nicely occupied DIN slot while GME not and will require to make some bracketing and even then will not sit that tightly.
Serg
Reply By: Member - Warfer (VIC) - Tuesday, Jul 29, 2008 at 19:18
Hiya Serg
I'd Swap no questions asked !
317947
Follow Up By: Member - Serg (VIC) - Tuesday, Jul 29, 2008 at 20:36
Knowing myself I think eventually I will. I just need to solve what to do with DIN hole and where to put GME. Do you know if any fascia available?
Serg
584366
Follow Up By: Member - Warfer (VIC) - Wednesday, Jul 30, 2008 at 21:13
Sorry Serg for the late reply...Looks like the boys hav set you right !
584631
Reply By: qubert - Tuesday, Jul 29, 2008 at 21:07
gme have got a good scan and sellcall setup
317990
Reply By: Member - Borgy.. (SA) - Tuesday, Jul 29, 2008 at 21:22
Serg is this the sort of thing you were after?? I got it with the UHF from a mob in WA over the net , cant remember their name right now , but someone on here will know who im on about, pretty popular mob
Cheers.......Borgy
Image Could Not Be Found
317995
Follow Up By: Member - Borgy.. (SA) - Tuesday, Jul 29, 2008 at 21:24
BTW Serg i forgot to say it was around the $20.00 mark and comes complete with mounting bracket for the UHF
584389
Follow Up By: Member - Serg (VIC) - Tuesday, Jul 29, 2008 at 21:34
Yep, thanks – this is what I am exactly after. I am in
Melbourne, thus SA suppliers not an option (unless they happy to send it over). Do you know manufacturer and/or model for me to search on net? $20 is not a problem – diesel cost much more nowadays :-)))))))
Serg
584391
Follow Up By: Member - Borgy.. (SA) - Tuesday, Jul 29, 2008 at 21:37
Serg i will see if i can find it for you , i paid for my UHF and the fascia panel with my card and i recieved them 2 days later
584392
Follow Up By: Member - Serg (VIC) - Tuesday, Jul 29, 2008 at 21:41
Thanks, waiting for more info.
Serg
584395
Follow Up By: Member - Borgy.. (SA) - Tuesday, Jul 29, 2008 at 21:54
This is where i got
mine from Serg
Prestige communications
Excellent service and very fast
Cheers......Borgy
584401
Follow Up By: Member - Serg (VIC) - Tuesday, Jul 29, 2008 at 22:05
Thanks, mate. I will check my supplier and if they got nothing suitable then I will definitely call Prestige communications
Serg
584405
Follow Up By: Member Brian (Gold Coast) - Wednesday, Jul 30, 2008 at 08:36
Serg,
I used the same fascia for some time..... does the job and looks very neat! Took it out 'cos I needed the DIN slot for something else and have mounted the GME in where the ashtray used to be.
Brian
584454
Reply By: Member - Phil G (SA) - Wednesday, Jul 30, 2008 at 10:42
I have two UH088 Unidens. I like the radio - only issue I've had in 10 years is a microphone replacement, and I like the front mount speaker.
If you're fitting that GME in the dash, I assume you'll be committed to using an external speaker??
318090
Follow Up By: Member - Serg (VIC) - Wednesday, Jul 30, 2008 at 11:01
Phil,
I have quite a few Unidens and generally happy with them. Not saying that something terribly wrong with Uniden – I just like GME more. Eternal speaker not an issue at all because I am already have one with Uniden and it nicely tucked under dash.
Serg
584481
