Reverse light problem solved and a further question
Submitted: Thursday, Jul 31, 2008 at 20:52
ThreadID: 60369 Views:1817 Replies:2 FollowUps:1
Thanks to those that helped me before. I ended up with a set of 55w Halogen Lamps mounted low.
I have a switch as suggested by Roachie so I can light up the area behind the vehicle, independent of being in reverse.
It works a treat.
Now a query for the 12v gurus
I have a 10 amp fuse in the relay coil circuit but i feel this is a little too high, should i drop to 5 amps to ensure it blows before damaging wiring?
Reply By: Member - Sam (NSW) - Friday, Aug 01, 2008 at 07:41
What guage wiring did you use mate?
AnswerID: 318439
Reply By: Member - Sam (NSW) - Friday, Aug 01, 2008 at 07:44
just did the calcs
assuming both lights are through the one fuse
55W x 2 = 110W
so using P=VI where P = power in watts and V = voltage and I = current in amps
110=12I
110/12=I
I= ~ 9.2Amps
so i would stick with the 10A fuse
if the lights are fused seperately, then a 5A fuse would be OK
AnswerID: 318442
Follow Up By: Waynepd (NSW) - Friday, Aug 01, 2008 at 10:15
cheers sam
FollowupID: 584919
