??? rediating areial
Submitted: Saturday, Jul 19, 2003 at 16:59
Member - Peter (WA)
Hi all I have just received a re radiating areial for my GPS with no instructions can anyone tell me where I should place the receiver end the long skinny thing ? should it be attached direct to the GPS or close but not touching it is an RA-45 any other hint on mounting it thanksBorn to drive a 4x4 , not a keyboard
York 4x4
Reply By: Member - Bonz (Vic) - Saturday, Jul 19, 2003 at 17:14
I have seen them mounted on top of a
snorkel, look like part of the furniture, higher is better I have been told.
Go hard then go home!So many
places to go!
So much work to do :0(
25356
Reply By: Member - Bob L - Saturday, Jul 19, 2003 at 17:18
Peter,
Checkout www.gpsoz.com.au, your antenna is listed under Aerials heading which states GPS end need only be near your GPS. Also has a specs page.
How about a report when you get it going?
Cheers Bob.
25357
Follow Up By: Member - Peter (WA) - Sunday, Jul 20, 2003 at 09:48
Bob L got it set up only took a few minutes to run the cable the receiver is magnetic ( on the roof) and the other end is now valcro to the side of the GPS holder , this unit plugs into cig lighter it has a great plug as you can still plug into the back of it without loosing use of lighter socket for other items .. As soon as I turned it one I could see the differance , it was a lot faster to track a lot of sats I am really pleased as I can now have the GPS positioned to where I can see it without worrying about it looseing signal strenght ... in all
well worth the $150 Peter..Born to drive a 4x4 , not a keyboard
York 4x4
17208
Reply By: Ray M (Vic) - Saturday, Jul 19, 2003 at 17:34
Go to the screen that displays the sat signal strengths. You can observe the difference the re rediating antenna makes as you move it around.Hooroo
25358
Reply By: Member - AndrewPatrol - Saturday, Jul 19, 2003 at 17:51
Peter,
I have one of those aerials too. So far all I do is stick the outside bit out the door so it gets shut in the rubber and stick the magnetic bit on the roof. I figure that you might as
well get things as close as you can by placing the outside receptor as close to above the GPS as possible. Another thing I've heard is that you should place the GPS somewhere its less likely to recieve its own signal, perhaps it'd get confused ( I put
mine on the centre console ) . I also stick my inside skinny bit directly to the GPS. The guy from GPSoz said about 6 inches is the limit but the closer the better. As said above just check your satellite screen. I also can higghly recommend the book Advertised on this site "GPS vehicle navigation in Australia".You'll find the signal is heaps better than a nude unit.
25359
Follow Up By: Member - Peter (WA) - Sunday, Jul 20, 2003 at 09:50
Andrew thanks , all set up and running spot on , I have that book it is
well worth a read and helped me on a number of thingsBorn to drive a 4x4 , not a keyboard
York 4x4
17209
