Tropical 3 way
Submitted: Monday, Jul 21, 2003 at 21:11
Mixo
Chescold 40L 3 way fridge/freezer - always been happy with it in mild to hot weather (on gas that is) - it has even done
well in 35 C for days on end (given cooler nights in between of course). Question is - does anyone have experience with a 3 way fridge/freezer in the subtropical far north ?(dry season that is). Compressor fridges are being discounted heavily in parts at present and I'm weighing up finances on a 3 way repair (240 volt circuit is out) versus getting into compressor fridges (and yep....I understand the energy supply implications thereof - its the 3 way on gas performance while in potentially hot regions that concerns me).Gotta have red sand on those boots !
Reply By: Mick - Monday, Jul 21, 2003 at 22:11
Mixo, for what it's worth, 99% if not 100% of caravans use gas/electric fridges - most don't have 12 volts being the only difference between them and the Chescold. They work just fine in Far north Queensland. I've spent a lot of time up there with my van. I've also used a Finch in the back of the wagon in Queensland in summer as far as
Townsville. Stinking hot and it worked fine. Many will tell you that they don't work
well in extremes but most often they are people who don't own one!
25546
Reply By: Rod - Tuesday, Jul 22, 2003 at 08:11
Had the blue Chescold with the freezer divider. Would periodically stop working on 12V, Gas and 240 and required turning upside down for a couple of hours to get it working again. Had it to repair
places in
Brisbane and
Darwin and was advised to get rid of it. Had to throw out many kilos of meat on
cape york.
I ran 6mm wiring to the fridge, was religious on trying to keep it level and
well ventilated. In the end, I've replaced it with a 60L Evakool and haven't looked back.
25568
Follow Up By: Member - Wherethehellawi - Tuesday, Jul 22, 2003 at 08:33
Rod, what you experienced with your absorption fridge is most probably caused by :
a) the the solution inside corroding the steel tubing giving rise to sediment which causes blockages internally.
b) the solution is crystallising causing a blockage.
Same as old kero fridges if they dont work turn em upside down, on their sides for periods of time and try again.....the idea being that the solution will attack/dislodge the sediment or dissolve the salts (crystallised). The solution is in most instances ammonia and
water. Any little bit of air (oxygen) that was not removed at time of manufacture accelerates the corrsion aspect. Crystalisation is caused .....hell ive gone overboard!
Anyhow, and as you were rightly told, if it keeps doing it get rid of it. Wow! am I cute
Richard
17326
Follow Up By: Rod - Tuesday, Jul 22, 2003 at 10:35
Since geting rid of my Electrolux, I've learn't that the manufacturer has three climate types for many of its three-way models. Climate Class S and SN designate a fridge designed to operate in ambient temps of up to 32 degrees C. Climate Class 'T' designates that it is designed to run in temps up to 43 degrees C.
Apparently, you can only tell by looking at the compliance plate inside the fridge. On the bottom line you will see 'Climate Class' the designation is immediately to it's right.
Thanks to Collyn Rivers for this tip.
17336
Follow Up By: GOB member vic - Tuesday, Jul 22, 2003 at 17:51
hi rod what does it mean when there is no marking beside climate class i just went and had a look after reading your post as i had trouble last year north of the alice .i think it might mean bulk buy by jayco at cheap price as when we got back to melb we had fridge tested and could find nothing wrong
gobits arrived just got to get photo and download
only 32 sleeps to go then off nth to
darwin yeah
17368
Follow Up By: Rod - Wednesday, Jul 23, 2003 at 09:15
Gob
Suggest you contact Dometic to find out. I no longer have an electrolux to check this info against, just passing it along from another
forum.
17409
Reply By: Member - Colin (ACT region) - Tuesday, Jul 22, 2003 at 11:34
There has been a lot discussion on this before - do a search on 3 way frigs.
The frig only needs to be level on gas - I have added a little spirit level to help with getting it level. Try rotating the frig (turning it over through 360 degrees as recommended by others). If you already have a heavy dedicated power wire the other modification is to add a 12v fav from a computer to the rear section which improves the air circulation around the heat sink. I also covered my Sadec (it is 20 years old !) with a self adhesive backed foam - aluminium foil from Clark Rubber. The heavy wire, fan and foil made a huge difference to the inside temperature. The cooling element inside now frosts up on 12v which it never did before the mods.
Compressor frigs are better in extreme conditions but don't have the versatilaty of running on gas when camped at one spot for extended periods - and they are expensive. Don't give up on the Chescol yet!
Colin - Subaru Forester
- size isn't everything ! -
25584
Reply By: Mixo - Tuesday, Jul 22, 2003 at 12:06
All good comment folks....thanks....I'm inclined to hang on to it at this stage... it rarely stops... have not needed to invert it much at all. I do use a spirit level. Have put the 12 volt fan in for mobile use...always runs on gas when we stop (and that gas factor is a bonus). I did put a small Dick Smith digi thermometer in it....... probe inside the fridge - readout module on the dash - can monitor 12 volt performance while mobile. Whatever. Gotta have red sand on those boots !
25592
Follow Up By: Glenno - Friday, Jul 25, 2003 at 19:38
Mixo,
I had the 240V "heater" element in my Electrolux replaced when it was 18months old. A fridge place at Strathpine (north of
Brisbane) repaired it for about $120 from memory. He says the 240v heater burns out quite easily in the Electrolux's and was surprised it had lasted that long.
17610
Follow Up By: Mixo - Saturday, Jul 26, 2003 at 09:39
Yep.....about $130 all up is still the quote for a new 240 volt element. Don't use the 240 V element much at all .... must be a combo of some use, and age -
mine did about 10 -12 years. 12 volt is still fine - gas always a winner. Cheers.Gotta have red sand on those boots !
17641
Reply By: Peter H - Tuesday, Jul 22, 2003 at 12:44
I have taken a three-way to
Cape York and over the Simpson. The more time you spend getting the setup (wiring in car) the better. I find the only limit is hot weather over rough roads. I'm not fully aware of the mechanics but I understand the power heats an element which heats some sort of fluid which then creates cold. If the fluid is being unsettled by rough roads it probably isn't heating properly.
I take a small line level which really helps. I dont have a burning desire to buy a compressor fridge.
25596
