That DC <span class="highlight">clamp</span> <span class="highlight">meter</span> from E-bay - report.
Submitted: Thursday, Sep 04, 2008 at 10:40
Mike Harding
I’ve performed a more detailed
test on it; results as follow:
All tests performed at 22C (I’ll try and do a few at 55C over the next week or so)
DC voltage – accurate to better than 0.7% over the range 100mV to 100V
Resistance – accurate to better than 1% over the range 10R to 5M
Frequency – spot
check at 1KHz, accurate to better than 2Hz
Duty cycle – spot
check at 50%,
meter displayed 50%
DC current (40A range) – accurate to better than 2%
DC current (400A range) – spot
check at 50A,
meter displayed 50.8A
NB. reversing the DC current flow direction through the
clamp cause the reading to change by a small amount but I do not consider this to be a significant problem given the likely applications for which this
meter will be used.
At ~A$55 delivered to Oz it’s excellent value for money as a general purpose automotive/caravan/camping
meter.
Mike
Harding
mike_harding@fastmail.fm
Reply By: Member - Ed. C. (QLD) - Thursday, Sep 04, 2008 at 10:51
Mike, Thanks for taking the time to do this!
(think I might go and get me one;-))
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
323772
Follow Up By: Trevor W(Brisbane) - Thursday, Sep 04, 2008 at 11:21
I would also like to buy one but have never bought anything on E bay
Ed. as your address is Qld and I live southside of Brisbnae I was hoping you would like to buy 2 and I will send you the Cash up front if you are near
Brisbane. my mobile is 0438 602533
590847
Follow Up By: Shaker - Thursday, Sep 04, 2008 at 18:50
Just register on ebay, do a search & buy one ... easy!
590879
Follow Up By: Member - Ed. C. (QLD) - Thursday, Sep 04, 2008 at 19:02
G'day Trevor,
I'm in
Toowoomba, but I'm sure we can work something out:)
Will probably get a couple of these anyway (one for daughter & SIL who are planning a 12 month working holiday 'round & across Oz w/- a caravan), so one more will be easy enough..
Having said that, as Shaker says, it's easy enough to register on ebay if ya choose to go that way... Will be in touch..
Regards, Ed C
| Confucius say.....
590885
Reply By: TerraFirma - Thursday, Sep 04, 2008 at 10:57
Hi Mike, What is the link for the product plse..?
323775
Follow Up By: Mike Harding - Thursday, Sep 04, 2008 at 11:11
This is a current auction
Link
showing the model of
meter I bought.
Otherwise do an E-bay search on "
clamp meter" and that should turn a few up.
Mike
Harding
590846
Reply By: Best Off Road - Thursday, Sep 04, 2008 at 11:24
Thanks Mike,
On your recommendation I'm gonna snag one of these, sounds like great value.
Jim.
323777
Reply By: Geoff43 - Thursday, Sep 04, 2008 at 14:00
Bought
mine from Hong Kong exactly the same model,downloaded English version operating manual (45 pages!) just typed into google UT203/204
Geoff43.
323788
Reply By: Member - Beatit (QLD) - Thursday, Sep 04, 2008 at 14:20
Thanks Mike, decided that I would finally buy one as
well. Been procxrastinating - mainly because of the local price! Anyway, time will tell how good they are.
Kind regards
Theo
323790
Reply By: deserter - Thursday, Sep 04, 2008 at 15:03
What do I use it for - can I measure what amps that implements are using ?
323793
Reply By: Member - JohnR (Vic) - Thursday, Sep 04, 2008 at 16:30
Good Mike, how about others that are sold in the Australian market? I say that as the one you have selected to
test may be a good one but where do other readily available one sit in comparison? Is it branded, is it easly replacable with the same brand and manufacturer?
So may people EO people I mean could be advantaged if you provided information as the Jaycar one and DSE if it was available. Then the information would be more useful to compare. I could even drop my Jaycar one in for you to
test when I go through
Melbourne if you would.
I guess then you would charge like Choice?
323801
Follow Up By: Mike Harding - Thursday, Sep 04, 2008 at 16:55
Frankly
John I doubt there is a great deal of difference when it comes to accuracy between these sorts of cheap meters.
Indeed it may but it was simply a random sample bought from E-bay so, equally, it may be a bad one?
To gain much more than I have recorded above one would have to
test a random sample of (say) five meters from different manufacturing batches and perform the tests over the full temperature range of the
meter (0 - 50C).
Although the companies who make these meters will try to maintain their quality they won't try as hard as someone such as Fluke so even if we did a batch
test on the Chinese
meter tomorrow the one they produce in 12 months time may be different in performance whereas the Fluke unit would be the same or better.
"Yer pays yer money and yer takes yer chances" :) but the above results should give people confidence to invest $55.
Mike
Harding
590865
Reply By: TrevorDavid- Thursday, Sep 04, 2008 at 19:25
Mike, interesting results what did you
test it against.
TDB
323822
Follow Up By: Mike Harding - Thursday, Sep 04, 2008 at 19:33
NATA calibrated kit.
Mike
Harding
590899
Follow Up By: Bonz (Vic) - Saturday, Sep 06, 2008 at 20:11
Was thinking the same thing myself, Mike we need to have a chat
591202
Reply By: Member - Phil R (Vic) - Friday, Sep 05, 2008 at 11:12
Hi Mike
I have been following your threads for quite a while now.
Thanks for the good report on this
meter,I have just bought one on ebay
323936
