generator
Submitted: Sunday, Jul 27, 2003 at 11:54
Member - Royce
I'm checking through archives.... but a bit more needed. I want to buy a small genny for travelling.... but at the moment am doing up a house I have had cut in half and shifted up from the big smoke to the bush block. Will one of the little
camping gennies work hand tools, small concrete mixer, pressure washer, vacuum cleaner? Which do you recommend and at what price?
Cheers RoyceRoyce www.funshow.com.au
Reply By: diamond (bendigo) - Sunday, Jul 27, 2003 at 13:03
gday royce.
the little
camping (cheap ones) are about 850 watt.
depending on the wattage of your mixer pressure washer ect if they use 850 watt or less then you wont have a problem i run a 850watt angle grinder of
mine and dosnt miss a beat.
the cheap chineese gennys are about $350 for 850 watt.
but i know you can get them in a bigger size not sure of the price.
if you go to www.helton.com.au.
i know member tony and helen sell them at therte site.new job coming so no fraser this time:-((
26083
Reply By: Member - Tony and Helen - Sunday, Jul 27, 2003 at 13:34
Hi Royce
Hand
tools are fine on the little gennies but larger draw appliances with electric motors requre 2 - 3 times the power to start the motor if you let me know the current/ wattage from the plates on the motors I can advise you further.
Tony
mail@helton.com.au she said you're
not going
down there with
me in here!
26084
Follow Up By: Member -BJ (Sydney) - Sunday, Jul 27, 2003 at 14:39
Tony how much to ship 1 of your gennys to
Sydney may as
well support a fellow member.Regards Bob
Where to next
17725
Follow Up By: Member - Tony and Helen - Monday, Jul 28, 2003 at 07:26
I'm not sure!!!
but I will Find out and get back to you later.
Probably worth finding a local distributor as freight could make it a bit dear.
the no e mails and phone calls on these gennies there are a lot of people considering them maybe we should all get together and make a bulk purchase
Chewers
Tonyshe said you're
not going
down there with
me in here!
17758
Reply By: Truckster (Vic) - Sunday, Jul 27, 2003 at 15:22
Hey Royce, check Ebay, theres some forsale under 4x4 accessories.
Hows the BFG's holding up??
Take care Mr.
26091
Follow Up By: Member - Royce- Tuesday, Jul 29, 2003 at 00:35
Doin fine! Busy.... just toured Tassie.... now to NSW. Catcha. Royce www.funshow.com.au
17835
Reply By: Mick - Thursday, Jul 31, 2003 at 22:04
Hi, about your genie,
if your building and renovating in the bush, youll probably need at least a 2000W genie, as small grinders and drills or other power
tools can use a lot of power. Spend a bit extra, but for travelling outback, i think an EU10i would be heaps, depending on how many 240 appliances you take travelling.
26465
