100 Series Headloght Adjustment
Submitted: Sunday, Jul 27, 2003 at 17:45
ThreadID: 6207 Views:2376 Replies:2 FollowUps:3
Hi Guys
I am trying to find the headlight adjustment points for my 100 series TD. I need to readjust them after some suspension modifications.
Any clues please.
Thanks & CheersPT
Reply By: Simon - Sunday, Jul 27, 2003 at 21:44
Paul,
on the back of the headlight there are two metal gear looking thingos, one is for up and down, the other for side to side.
It appears you use a flatbladed screwdriver to lever the wheel around.
I would Imagine taking it to a dealer or garage wouldnt cost much and they should have the proper thing to align them properly.
AnswerID: 26114
Reply By: Member - Wherethehellawi - Thursday, Jul 31, 2003 at 08:20
Paul,
I have settings for 100 petrol (Photocopy somewhere in this office) that toyo dealer gave me.
Do you need details or do you have?
RichardWow! am I cute
Richard
AnswerID: 26411
Follow Up By: Member - Paul T- Thursday, Jul 31, 2003 at 08:47
Richard
If you send the details to me that would be greatly appreciated.
Can you upload to this site (Exploreoz) or do you need my email address.
PT
FollowupID: 18031
Follow Up By: Member - Wherethehellawi - Friday, Aug 01, 2003 at 12:01
Paul,
How do I upload to exploreoz so u can get hold of it????....and hell i thought I wasnt a complete dummy when it came to computers?Wow! am I cute
Richard
FollowupID: 18131
Follow Up By: Member - Wherethehellawi - Friday, Aug 01, 2003 at 13:59
Paul now that I have found the details its simple really.
Square car up at at 90 degrees 3000mm from wall
Centre of Low beam image on wall should be 50.8mm below actual centre of headlight which would vary depending on weight of car and or suspension lift and of course carry weight. I use std 960mm actual headlight centre for empty and then adjust lights when I carry extra weight.
Distance apart is 1209mm centres
If you have a lift kit then you'll most likely need to adjust and to make things easy drop by 50mm (from actual lamp centre height) at 3000mm. Its not accurate but its close enough and you will reduce the abuse from other motoristsWow! am I cute
Richard
FollowupID: 18149
