Interior Lights (Done!)
Submitted: Sunday, Jul 27, 2003 at 22:07
Truckster (Vic)
Went to Jaycar today and bought a fluro light complete.. With a little hacking Luke (electrical GURU) got it workin the rear section with the Interior.
IMPRESSIVE is an understatement. its Brilliant! His missus is expecting one now in the Mav ;)~
http://www.jaycar.com.au/
11watt 12vDC PL Cabin Lamp.
Part # ST-3006 $29.95.
The LED replacement lights are for interior lights are
Part KC-5334 for 31mm Festoon replacement $4.95!!!
Part KC-5344 for 41mm Festoon replacement $4.95!!!
PART KC-5349 for Bayonet Replacement Globe $8.95!!
Enjoy it people!!!
Heaps of thanks to Luke for his help, and Hayley his missus for gettign rid of my missus from the house for the day!
Reply By: Member - Toonfish - Sunday, Jul 27, 2003 at 23:26
I thought i noticed a distant glow from your direcion man is that sucker
bright?1999 NISSAN NAVARA DUALCAB
DIESEL 3.2 & SPRINGY CARLTON TOY
26121
Follow Up By: Truckster (Vic) - Monday, Jul 28, 2003 at 11:27
Actually it is! :)~
17762
Follow Up By: Member - Bonz (Vic) - Tuesday, Jul 29, 2003 at 19:59
If I turn up this Saturday night up
the Pyrenees Bruce, I'll just follow the light to you, sorta like another event about 2000 yrs ago.............So many
places to go!
So much work to do :0(
17880
Reply By: petprass - Monday, Jul 28, 2003 at 08:55
I was looking at the same interior light kit from Jaycar - but the 31mm kit was KC-5354 not 5334. Is that the same one?
Also on the web page, it says "Use broken globes for fittings". I take it that you just get an old festoon globe that has deceased, break the glass and insert the 2 LED kit - is that all you have to do? If it is then I am going to get two sets. One for the very back light and one for the middle light in the GU Patrol. I already have quite powerfull map reading lights in the front - built into the overhead radio console, but they do not turn on automatically when the doors are opened so I have to rely on very dim middle and back lighting.
26128
Reply By: Luke - Monday, Jul 28, 2003 at 10:37
The Jaycar LED kits look very good - I'll be geting a few to try soon.
LED's and Festoon light globe end must be supplied by you, and are not part of the kit.
The JayCar flouro light is a great unit - very
bright indeed, and should theoretically have a current drain when on in the vicinity of 100 milliamps, so
battery power shouldn't be too much of an issue.
To get the light working with your door light switches requires a little bit of a hack...we disconnected the pitiful courtesy lamp that comes in the flouro light as an extra - and utilised the SPDT switch to switch a common earth to either the door light earth - or a permanenet earth, giving the light three states: OFF, ALWAYS ON, or ON WITH CABIN COURTESY LIGHTS.
It works very
well - after the required modification is done to the flouro light unit - just tap into the existing cabin light loom for the required +12V, -12V, and switched -12V lines.
Luke.
26137
Follow Up By: petprass - Monday, Jul 28, 2003 at 11:52
Luke,
Do you say that you have to supply your own LED's as
well? I thought that they came with the kit. If not then do Jaycar sell them?
17763
Follow Up By: Truckster (Vic) - Monday, Jul 28, 2003 at 12:47
Nope the LEDS are in kit.
You need to supply the ends of the Festoon globes.
17768
Follow Up By: Luke - Monday, Jul 28, 2003 at 19:50
It says in the Jaycar catalogue that "LED's and fittings(festoon ends) not supplied"
Any which way, Jaycar will have the LED's, and they are nice 'n' cheap.
17808
Follow Up By: Luke - Wednesday, Jul 30, 2003 at 09:32
Bought a kit yesterday - haven't made it yet - will try to get 10 mins tonight :-)
...In kit the only thing supplied is a PCB, and instruction sheet. You have to buy 2 LED's (for the 31mm kit - you can select your own depending on brightness/colour desired. I bought 7000Cmd LED's in white - they are the brightest that Jaycar stock), a resistor (value depends on the LED's you select), and a IN4004 diode.
Total cost (assuming you can get the festoon light end caps for free- I'm gonna just break the one in the car and use that) is $13.63 from Jaycar for one lamp replacement including all components. This gives you enough resistors and diodes for a few kits though, as they are not available seaparately and are sold in small packs.
Will post more info and results when I've built it :-)
17919
Follow Up By: petprass - Wednesday, Jul 30, 2003 at 11:46
Luke,
I am keen to get a kit myself. I am hoping that it will light up the whole of the back area of the GU with just the very back light (cargo area) being converted.
17929
Follow Up By: Truckster (Vic) - Wednesday, Jul 30, 2003 at 13:23
Petprass.
in that case you want the Fluro kit I got.. you put it in as
well as the interior, I err Luke mounted
mine above the double doors on the back wall center
17938
Follow Up By: petprass - Wednesday, Jul 30, 2003 at 14:00
Hey Luke - how many beers will it take to do my GU with the fluro kit??
I understand that practice makes perfect.
17943
Follow Up By: Luke - Wednesday, Jul 30, 2003 at 14:32
Hey petprass,
Where are you located - I'm sure we could work something out :-)
17948
Follow Up By: Luke - Wednesday, Jul 30, 2003 at 14:33
Probably easier if you just drop me a line.....
swbmav @ yahoo.com.au
Luke.
17950
Reply By: Gerry - Monday, Jul 28, 2003 at 11:16
Truckster,
Looks like you sorted out the interior light issue, however, I did say that I would take a coupla pics of the Magna interior lights in my GQ for ya - and I did. If you're still interested, where do I email 'em to mate?
Gerry
26140
Follow Up By: Truckster (Vic) - Monday, Jul 28, 2003 at 12:00
I still have to do the front of the car, thats in the cargo area.
vfr750fv
at
yahoo
dot
com
thanks
Me.
17764
Follow Up By: Shannon - Monday, Jul 28, 2003 at 18:26
Hey Gerry (or Truckster) can you please forward me some pics of the Magna light set up...
-Shannon
shannonc@optusnet.com.au
17801
Reply By: Janset - Monday, Jul 28, 2003 at 20:06
Hi Guys.
Would someone out there please sum up the end result for a poor old Troopie owner. My interior dome light is the 30 mil length, and I think the rear courteous light is the same. From what I can guesstimate I can only fit a 2 LED type into the existing light fittings. (Jaycar)
Are they
bright enough, better that the existing 5 watt dim globe?
What other alternative do I have for a brighter light, is there something else out there that is in existence other that the Luxeon in a earlier post?
A summary if someone can see their way to do so please.
26186
Follow Up By: Luke - Monday, Jul 28, 2003 at 21:16
I'll be testing the 31mm LED festoon replacement kit sometime this week.
I'm sure it will be an improvement over the standard cabin light - only thing is how much of an improvement really :-)
...will post results when I've built one...
Luke.
17819
Follow Up By: Janset - Tuesday, Jul 29, 2003 at 13:49
Hi Luke.
Eagerly awaiting your assessment.
17856
Follow Up By: Allyn (Pilbara) - Thursday, Aug 14, 2003 at 00:20
Janset
Check this site out.
http://www.geocities.com/george_tlc/LED.html
Not sure if 75 is same as 80 series (can't imagine why it wouldn't be) but I fitted mine last night and it's made the cabin a tad short of daylight.
Very impressed
Next Trek - Callawa Rd
19188
Follow Up By: Janset - Thursday, Aug 14, 2003 at 16:27
Hi Allyn.
I have been to Georges site before and I have to say I am VERY impressed and dearly love to get one, but when Ii mentioned it to the wife, she almost went ballistic over the price. I tried to explain to her that the parts were expensive but the answer I got was "use a torch".
The next time I see an series 80 I will have a look at the interior light.
Incidentally your site listed came up with "Yahoo unable to find site"
Isn't it a bugger when you have to count the pennies?
19254
Reply By: Matt (W.A.) - Tuesday, Jul 29, 2003 at 09:08
After the previous Posts I purchased a couple of the kits from Jaycar
Perth
$43.70 later....for 2x31mm amd 1x41mm Kits the "KIT" consisted of the Instructions on how to make the led and the PCB Board but I then had to purchase the Diodes and Resistors and LED's Seperately, it also depends on what type of LED's you put in i used 5mm 6000mCd High Brightness LED
Completed a 31mm LED for the rear of my Paj and I think its Brighter! will probably go with the 11watt 12vDC PL Cabin Lamp. Part # ST-3006 $29.95. less hassle I think......
HTHKeep It On The Rough Stuff
Matt (W.A.)
26230
