Port Poties
Submitted: Monday, Jul 28, 2003 at 18:26
ThreadID: 6226 Views:2080 Replies:5 FollowUps:1
Does anybody know a chemical means of removing the scale build up that is found in Porta Potis?
Reply By: Lyds - Monday, Jul 28, 2003 at 18:52
napalmCheers,
Stuart
- To err is human, to moo bovine -
AnswerID: 26178
Follow Up By: raybates - Monday, Jul 28, 2003 at 18:55
Ha Ha big deal
FollowupID: 17803
Reply By: B.P. - Monday, Jul 28, 2003 at 19:28
Ray
Been using a porta potti for a couple of years and haven't had the prob.I always use liberal doses of both chemical when in use and wash out thoroughly before storing with abit of chemical and water sloshed around inside first. If its a urinal type buildup your refering to,try a retailer of cleaning chemicals, their bound to have something.
B.P.
AnswerID: 26182
Reply By: Member - Jack - Monday, Jul 28, 2003 at 21:59
Hi Raybates:
I don't have a PortaPottie, but I would probably try some of that CRC .. I use it mainly for removing scale in the dishwasher at home, and it seems to remove everything. I guess I'd read the label first to make sure there will be no damage caused ... just a thought ..
Jack
AnswerID: 26200
Reply By: Member - Roger - Monday, Jul 28, 2003 at 22:10
Ray
I have used a p/poti for five years and have not had this problem. I always wash the unit out before storage and put the usual amount of chemicles in and add a little water, about 1 ltr to the bottom tank.
I was told to always use the upper tank additive to stop scaling and to help with any odours.
Maybe the suggestion of CLR might work.
RegardsDodg
AnswerID: 26203
Reply By: Member - Al & Mrs Al (Vic) - Tuesday, Jul 29, 2003 at 07:27
Hi raybates,
I've never had to clean a porta potti [yet!], however I have had to get some tough scale build up off other places and I find the orange based cleaners work really well, you could also give them a try.
Lyn [Mrs. Al]1927 Oldsmobile Tourer
Corrugations...what are they?
AnswerID: 26222
