Hot water on tap
Submitted: Tuesday, Jul 29, 2003 at 17:55
ThreadID: 6248 Views:2366 Replies:3 FollowUps:6
I know a bloke in the bush who deals in outback vehicle recovery. He has a Landcruiser Ute with a rear mounted winch and he tows a car carrying trailer.
Being a meticulous fella, he finds the need to keep clean after a recovery job. Don't we all? Anyway, he built a stainless steel tank which incorporated a pipe through which the stainless steel exhaust passed thus supplying him with piping hot water after only driving a small distance. I think that the filler cap is vented for steam evaporation. He also built a similar size tank for cold water and ran the two outlet pipes into one so that he could regulate the temp of the water. Both these tanks are fitted under the tray of the ute.
Now this idea may only be applicable to Utes and Troopcarrier type vehicles and not to our run of the mill wagons. But it is a good idea? All you would need is a set of ramps to drive up so that you could have a shower underneath:-)
Cheers, Willem
Never a dull moment
Reply By: Wazza (Vic) - Tuesday, Jul 29, 2003 at 18:04
Or, use one of those fold up boat thingys for a bath.Cheers,
Wazza
AnswerID: 26266
Reply By: Truckster (Vic) - Tuesday, Jul 29, 2003 at 19:39
It is a good idea, but I personally think to draw the line somewhere.
Club Ex Presidents GQ is just over 3200kgs driving around Mon to Friday with tanks, taps, air, compressors, and you name it its in there...
The car must be the biggest pig to get started, clutches must last about 100klms!
AnswerID: 26277
Follow Up By: Member - Willem- Tuesday, Jul 29, 2003 at 20:06
How much does your GQ weigh? Must be quite close to the 3 tonne. But I agree, you can end up with too much gear. My old truck weighs in at 2695kg fully fuelled with two humans, tucker and all their gear on board. The GVM is 2769kg.Cheers, Willem
Never a dull moment
FollowupID: 17883
Follow Up By: Truckster (Vic) - Tuesday, Jul 29, 2003 at 20:11
Arent GQ's 2200??
If not his car is lots more then.
Its Crazy.. But he can do week trips in minutes he is ready to go!
FollowupID: 17886
Follow Up By: Member - Willem- Tuesday, Jul 29, 2003 at 20:20
Truckster,
Go outside and have a look. It should be on your compliance plate. 2200 seems a little light for a GQ. At that weight you may only have place for a picnic basket :-)Cheers, Willem
Never a dull moment
FollowupID: 17888
Follow Up By: Truckster (Vic) - Tuesday, Jul 29, 2003 at 21:19
Stuff that!!
Its Hailing outside!!!!
FollowupID: 17891
Follow Up By: donc - Tuesday, Jul 29, 2003 at 21:51
Tare wieght on a GQ is 2180kg and GVM is 2800, got it left on the side of my vehicle when telstra got rid of it
FollowupID: 17895
Follow Up By: colin - Wednesday, Jul 30, 2003 at 10:11
tare on a GQ is1800 and gross 2800. Col
FollowupID: 17921
Reply By: Steve from Drive Systems Victoria - Wednesday, Jul 30, 2003 at 08:43
My GU tray top weights in at 2500kg EMPTY, unladed, zip fuel.
AnswerID: 26320
