OT Metal Detectors
Submitted: Thursday, Oct 23, 2008 at 06:51
landed eagle
Greetings to the wise and all knowing forumites!
Young bloke has expressed an interest in having a metal detector for Xmas present. Dont want to waste cash on a useless toy. Anyone out there recommend a type/brand that they might be using for fossiking that performs
well?
Thanks and safe travels.
Reply By: Willem - Thursday, Oct 23, 2008 at 06:58
Yep
Minelab 4500 is supposed to be the best. Google it. Set-up costs around $7000. THis one si for the serious prospector
I have a Minelab Xterra 70 Treasure Detector. Set-up costs around $1400
Hope you have deep pockets!
331361
Follow Up By: Member - Kiwi Kia - Thursday, Oct 23, 2008 at 09:01
Willem, arn't you actually suposed to be 'out there' with a detector in your hand today ? I had heard that today is the day that the treasure map is comming out of the bank vault.
599154
Reply By: tuck 01 - Thursday, Oct 23, 2008 at 08:29
Eagle
Cannot talk from my experience because I have just brought my first detector. However, I canvassed widely among experienced prospectors before the purchase.
I received two pieces of advice. 1. Buy the best you can afford. 2. Minelab 4500 is the best.
Hence, I am the proud owner of a 4500.
Cost is high but not quite as bad as Willem indicates.
I'm looking at a reeipt for $6356 including GST, but this also covers an extra coil, pick and magnet, external speaker, electronic scales, some reading material and a couple of Miner's Rights.
The cost of the 4500 alone was $5700 incl GST, but at a minimum you will need another coil, a pick and magnet and a Miner's Right.
I brought
mine from CoilTek in
Maryborough (VIC).
Jeff
331366
Reply By: troopyman - Thursday, Oct 23, 2008 at 08:31
As someone who has actually owned detectors , i will ask do you want to hunt for gold or coins ?
331368
Reply By: Member - Doug T (NT) - Thursday, Oct 23, 2008 at 08:34
I see you mention it's for the
young bloke for xmas, you don't say how old he is so I presume he's somewhere between 8 and 16 so I'm sure for a first detector you sure don't want to spend up big on a Minelab as mentioned at $7000 , I would be looking at the Garret range , around the $350 and upwards.
Miners Den
331370
Follow Up By: Member - Doug T (NT) - Thursday, Oct 23, 2008 at 08:44
Ths is a better Garrett link
Garrett Detectors
599149
Follow Up By: troopyman - Thursday, Oct 23, 2008 at 08:45
If you want coins then bounty hunter land star for about $700 is ok used in all metal mode . You wont do any good with it in hot (mineralised goldbearing ground) though .
599150
Reply By: Keith_A (Qld) - Thursday, Oct 23, 2008 at 09:37
Hi LE - there are basically 3 types of detectors.
1. Specialised gold detectors - Minelab is the best, but only worth the investment if you live near, or travel to, recognized gold fields. Suited for the serious prospector/fossicker. Around $5000.
2. Coin, jewellery and relic detectors. Several brands available, with Minelab up at the top. A Minelab X-Terra will set you back about $600 - not a toy, but not costing an arm and a leg. (For about $1,300, you get the Minelab Quattro - the next model up). These can be used on beaches, parks,
camp grounds etc.
3. Toys - Able to detect to about 2" in loose sand - see Kmart - $100.
I bought a Quattro on the Net several years ago, and use it anytime we are near a beach. Good exercise, great
recreation, and it has paid for itself several times over.
Usual disclaimer - Not associated with Minelab, no shares in coy etc, just happy with the product.....................Keith.
331382
Reply By: Topcat (WA) - Thursday, Oct 23, 2008 at 10:45
My advice to you is to Google the Prospector/Fossicking forums & do some research on the subject & that will save you a lot of money & also the advice given will get you the best value for your money. If this person is really serious about detecting then look around for a good second-hand unit (The Minelab SD series is a good starter), learn how to use it then upgrade to the more expensive units. Cheers.
331397
Reply By: landed eagle - Friday, Oct 24, 2008 at 07:21
Thanks to all contributors. Has given me food for thought.Was thinking around $700.00, so at least I've somewhere to start as far as models/brand go.
331576
