Site Search
Section Image
12volt Car and camper trailer setup
Submitted: Wednesday, Nov 12, 2008 at 11:08
Bruce n Sal
Article Overview - Caravan & Camper Battery Charging
Our modern lifestyle and need for electric and electronic products to accompany us on holidays and on our travels has brought us to have independent power in our caravans and campers when away from mains supply. View Full Article...
Hey Guys,
I am trying to get prepared for my camping setup.
I want to setup a dual battery system in the car for the fridge (Waeco 80ltr). Also I want to have another battery in the camper trailer to run an inverter and some 12volt lights etc.
My main question is what do I need to be able to charge all batteries while driving.??
I am thinking an anderson plug on the rear of the car connected to the trailer and some sort of switch to charge the batteries in sequence. Is this possible.???
Also I want to have the option to add solar panels to recharge the system at a later date. What sort of equipment would I need.
Is there a way to charge to aux battery in the car and the trailer with a generator without having to take the batteries out.??
Bruce
Advertisement
ThreadID: 63458 Replies: 4
Views: 3298 FollowUps: 10
AnswerID: 334848   Submitted: Wednesday, Nov 12, 2008 at 11:49
Member - 1/2A replied:
Here's a good place to start
Morning tea far North Queensland
Click Image to Enlarge
Microsoft is like an air conditioner when you open the Windows it stops working!
Ubuntu 9.04 Linux 64 bit.
I don't support the M$ Empire!
Reply 1 of 4
AnswerID: 334849   Submitted: Wednesday, Nov 12, 2008 at 11:56
Robin Miller replied:
There are a number of approaches Bruce - some better and some
more costly, however you can start by simply connecting all the
batteries together and also just plugging in your charger across
them all.
There is no need to remove batteries to charge.
From there you may move to the various options of adding in dual
battery controllers and even a step up voltage charger for the trailer.
Just make sure everything is fused , and that your waeco fridges low voltage cut out is set and working.
A small solar panel (<40watt) can just be plugged straight in to charge the batteries for a few hours at a time , and as you get more powerful panels you will need a solar panel regulator.
One of the most useful accessories when doing a simple setup and then growing is to have an accurate voltmeter connected across the batteries at all times so you can keep an eye on them without have to stuff around.
Survivor -Top Crossing Hut Trk
Robin Miller
Reply 2 of 4
FollowupID: 602620   Submitted: Wednesday, Nov 12, 2008 at 12:21
Bruce n Sal posted:
Thanks,
Do you know any places I can get one of these. And find anymore info on them.
FollowUp 1 of 6
FollowupID: 602621   Submitted: Wednesday, Nov 12, 2008 at 12:24
Member - 1/2A posted:
Use the link on my first post and you'll be able to get every thing you need.
FollowUp 2 of 6
FollowupID: 602623   Submitted: Wednesday, Nov 12, 2008 at 12:34
Bruce n Sal posted:
Thanks I will have a look at it.
FollowUp 3 of 6
FollowupID: 602643   Submitted: Wednesday, Nov 12, 2008 at 14:26
RV Powerstream P/L posted:
Hi Bruce and Sal
If I can be of any help please contact me through the trader section of this forum.
The picture below is a new Zero Volt battery Splitter that has multi channels for multI batteries with over volt protection and backfeed protection and greatly improves the charge to your batteries from the ALTERNATOR.
Email me and I will try and assist .No Obligation whatsoever.
Ian
RV Powerstream P/LRV Powerstream P/L
Business Member: My Profile  My Blog
FollowUp 4 of 6
FollowupID: 602646   Submitted: Wednesday, Nov 12, 2008 at 14:43
Best Off Road posted:
Bruce,
Ian is a straight shooter.
You might also talk to him about the Sterling charging unit, to ensure you are getting maximum power output. If you get one of these and self fit, it will work out similar in cost to getting a traditional (and less efficient) system.
Ian kindly donated one of these units for Michael Mitchell who is currently doing the "Great Cancer Bush Walk". Ian sent it down to me to fit to Mike's Jackaroo and it was a doddle (and I'm not an Auto Electrician's arse).
Jim.
Best Off RoadBest Off Road
Trader: Drawers
FollowUp 5 of 6
FollowupID: 602653   Submitted: Wednesday, Nov 12, 2008 at 15:08
Robin Miller posted:
Thats certainly an interesting device.
(Electronics engineer here and Ian sent me the brochure).
While I have no technical information nor have done any engineering tests , this sort of thing is the way technology is moving, as is beginning to be seen in such things as winch controllers.
I presume its based on power mosfet switching backup up by a microprocessor monitoring current flows into/out of each terminal based on use on small shunts.
I guess proof will be in the actual implementation and cost, but concept is sound.
Robin Miller
FollowUp 6 of 6
AnswerID: 334897   Submitted: Wednesday, Nov 12, 2008 at 19:29
Wheaters replied:
I am doing exactly the same,
I am trying to run a thumper 75amp as a car setup and then run the thumper 120amp in a trailer.
I have been told if I run the thumper 75 in the car I can charge it as I drive and use it to run my fridge.
Then when I return I can hook it upto thee trailer and it will trickly dump into my trailer 120 amp.
The enquiries I have made are via a site called
http://www.homeof12volt.com.au/
Cheers John
Reply 3 of 4
FollowupID: 602681   Submitted: Wednesday, Nov 12, 2008 at 20:04
Sand Man (SA) posted:
John,
I have a dual battery setup in my Jack, controlled by a Piranha DB150S Controller.
On top of this I also have a 75Ah Thumper and a 39 amp in-car charging unit.
The way it works is this:-
The DB150S prioritises the starting battery to receive whatever charge that is necessary from the alternator, then once it has reached a specific voltage, will swap over to allow anything connected to the auxiliary circuit to be charged.
This generally happens within a minute or so because the starting battery is in good condition and not normally subjected to much current draw.
Once the auxiliary circuit is connected through the controller, the auxiliary battery in the engine bay receives whatever charge that is required.
The In-car charging unit for the Thumper is also connected to the auxiliary battery, so charging current also flows through the circuit to the Thumper in the back and connected whilst travelling.
The fridge is connected to the auxiliary battery when travelling, then when setting up camp, I remove the thumper and fridge and locate in the annex of the camper trailer. I also connect an 80 watt solar panel to the thumper to help maintain a charge for an indefinite period.
The auxiliary car battery is a backup should I need it, but that is unlikely.
In your situation, you don't need the dual battery controller, simply the in-car charging unit for at least the 75 Ah unit. This would be connected to your primary battery.
For the 120 Ah battery in the trailer, I would be inclined to have a separate circuit via an Anderson connector to and Arrid Twin Charge controller in the trailer and then to the trailer battery.
This setup will limit the need for heavy duty cable, but increase the voltage at the remote (trailer) end to enable correct charging of the trailer battery through the vehicle alternator.
The Arrid Twin Charge Controller setup is very common for correct charging of remote batteries by the vehicle alternator. It boosts the voltage level if necessary to remove voltage drop, the most common cause of inadequate voltage supply to a trailer battery.
Although the Arrid Twin Charge may also be possible of charging the Thumper in the back of your vehicle, I would prefer to have two separate circuits, one for each battery system.
I am sure you will receive expert advise from the guys at Home of 12 Volt.
Just be aware there are several ways of achieving a good result.
Bill
HooRoo !
FollowUp 1 of 4
FollowupID: 602694   Submitted: Wednesday, Nov 12, 2008 at 21:51
Correction!
In my reply above, 39 is a typo.
The in-car charging units available are a 20 amp, or the heavier duty 30 amp unit.
HooRoo !
FollowUp 2 of 4
FollowupID: 602696   Submitted: Wednesday, Nov 12, 2008 at 21:55
Wheaters posted:
what are your thoughts on projecta pure sine invertors??
FollowUp 3 of 4
FollowupID: 602697   Submitted: Wednesday, Nov 12, 2008 at 22:02
Don't have any particular experience with the Projecta Inverter.
I have a 300 watt modified sign wave inverter infrequently used to run a small AA battery charger, or a charger for the video camera.
That is my sole need for an inverter.
I have structured my camping needs for 12 volt lighting only, plus running the fridge.
Bill
HooRoo !
FollowUp 4 of 4
AnswerID: 334908   Submitted: Wednesday, Nov 12, 2008 at 20:23
Affordable Batteries & Radiators replied:
Hi Bruce
Which ever system you use I recommend using the 50A Anderson plugs as a common connector to enable you to charge all batteries and also connect solar, mains chargers and the car to all sources and batteries.
Derek.
ABR - SIDEWINDERABR - SIDEWINDER
Reply 4 of 4
Activities Index
Melbourne Sports Tour MCG PLUS The Neighbours Tour Melbourne Sports Tour MCG PLUS The Neighbours
Melbourne - VIC
This is the Melbourne you came to see! Explore Melbourne and our world class sporting venues.
V8 Race Car Driving Experience - 11 Laps, Vic V8 Race Car Driving Experience - 11 Laps, Vic
Melbourne - VIC
Experience life in the fast lane as you get behind the wheel during this V8 race car driving experie
Full Day Sailing on Sensational Sydney Harbour Full Day Sailing on Sensational Sydney Harbou
Sydney - NSW
Sydney Harbour is an amazing place! Vibrant, exciting, breathtaking.
Tandem Skydiving on the Beach Tandem Skydiving on the Beach
Sunshine Coast - QLD
Skydive from up to 10,000 ft over the spectacular Sunshine Coast.
Book Now - Things To Do
