Site Search
Section Image
Problem with TV adapter
Submitted: Tuesday, Dec 02, 2008 at 14:26
Bunny
Article Overview - Caravan Antenna
As all antenna designs are a compromise at some frequency, the trick is to work out what will give you the least compromise. View Full Article...
Hoping someone can help - we seem to have a problem when plugging our TV into the battery source. The battery adaptor goes into a wall plate which also houses the plug for the Winegard aerial, with a button which shows green when the aerial is working. (Sorry if this is a little sketchy but I'm not the technical type).
We can make the TV work when plugged into normal power, but neither the adaptor nor the aerial green light seems to work. Could it also perhaps be the "plate" on the wall?
We are trying to replace the adaptor but can't seem to find the exact one - has anyone any suggestions as to where these can be bought.
Thanks.
Advertisement
ThreadID: 63964 Replies: 4
Views: 1170 FollowUps: 2
AnswerID: 337871   Submitted: Tuesday, Dec 02, 2008 at 14:42
rredbeak replied:
try a company called Camec , if theres none in your city then look up camec.com.au on the net and browse their catalogue... HTH.. Rod
Reply 1 of 4
AnswerID: 337873   Submitted: Tuesday, Dec 02, 2008 at 14:51
Bunny replied:
We have looked at the catalogue at Camec but they don't seem to have the adaptors.
Reply 2 of 4
AnswerID: 337875   Submitted: Tuesday, Dec 02, 2008 at 15:09
gottabjoaken replied:
By "adaptor" do you mean a "cigarette lighter" type plug?
Ours need to be pushed very hard into the socket on the Winguard fitting.
Try taking it to your car and see if the tv does work on twelve volts when plugged into the cigarette lighter in the car.
There are possibly two types of Winguard fitting with the green light. The more modern one has a push button switch beside the green light that turns the amplifier on and off. On when the light is on. Off will usually give no television signal to the tv.
Another sort of Winguard fitting MIGHT use the push button switch to switch between the aerial and an external aerial input (like when plugged in to a caravan park tv plug).
I am not sure if this type is common here, and you would have to read your instruction manual carefully to see which type you have.
If the green light does not come on when you click the push button, then check the fuses. Or check your 12 volt supply.
good luck
Ken
Reply 3 of 4
FollowupID: 605432   Submitted: Tuesday, Dec 02, 2008 at 15:14
Bunny posted:
Thanks Ken, your comments have been very useful. I will pass them on to the Minister for Technical Support, i.e. hubby.
I think our fitting is the first one and our manual is somewhat lacking. Hubby did check fuses, and our 12 volt supply seems okay because our lights are working.
Will definitely try the car to see if the TV works.
Thanks again.
AnswerID: 338032   Submitted: Wednesday, Dec 03, 2008 at 12:31
Bunny
this may help
winegard manual http://www.winegard.com/mobile/pdf/2452013.pdf
Ken
Reply 4 of 4
FollowupID: 605730   Submitted: Thursday, Dec 04, 2008 at 08:39
Bunny posted:
Much appreciated Ken. Will advise when and how we solve our little problem.
Activities Index
Dolphin Adventure by Kayak Dolphin Adventure by Kayak
Sunshine Coast - QLD
Explore the magnificent Noosa National Park coastline by kayak.
Corporate Movie Trailer for up to 20 Corporate Movie Trailer for up to 20
- INT
Ever wanted to be in the movies?
Riverboats on the Murray Riverboats on the Murray
Adelaide - SA
Travel through rolling hills and Mallee outback to the mighty Murray River, bringing watered life to
Didgeridoo Lessons - 4 Week Course Didgeridoo Lessons - 4 Week Course
Perth - WA
This didgeridoo course is world famous for its success with taking people from never having tried th
Book Now - Things To Do
