Sunday, Jan 25, 2009 at 02:55
Again
Its a minefield...I still don't believe the towing combination you mention falls within the scope of those posred ADR's if you read the posted link carefully
[quote]
6. TOWBAR REQUIREMENTS
6.0. The requirements of this Section do not apply to connection devices mounted at the front of a motor vehicle or devices not intended for towing trailers.
6.1. Strength Requirements
The vehicle structure including the ‘Towbar’ must either:
6.1.1. be able to withstand the following forces applied at the intended ‘Coupling’ centreline without any residual deformation that would interfere with or degrade the function of the assembly, nor must there be any breaks, cracks, or separation of components:
6.1.1.1. In the case of ME, NB and NC category vehicles:
6.1.1.1.1. longitudinal tension and compression 1.6 × ‘Coupling’ ‘D-value’ required for use with the ‘Aggregate Trailer Mass’ marked on the ‘Towbar’ according to clause 6.3.1.3; or
6.1.1.1.2. a dynamic oscillating force of ± 0.6 × ‘Coupling’ ‘D-value’ required for use with the ‘Aggregate Trailer Mass’ marked on the ‘Towbar’ according to clause 6.3.1.3 for 2 million cycles. The frequency not to exceed 10 Hz but must be chosen not to coincide with the natural frequency of the system.
6.1.1.2. [B]In the case of L group[/B], MA, [B]MB,[/B] MC, MD and NA category vehicles:
6.1.1.2.1. longitudinal tension and compression l.5 × the ‘Towbar’s’ rated capacity;
6.1.1.2.2. transverse thrust 0.5 × the ‘Towbar’s’ rated capacity; and
6.1.1.2.3. vertical tension and compression 0.5 × the ‘Towbar’s’ rated capacity; or
6.1.2. [B] comply with AS 4177.1-1994 for vehicles equipped with ’Towbars’ designed for towing TA and TB category trailers.[/B]
Hopefully my bolding will show the appropriate bits.
Lastly the category of traiilers specified here are light and very light! (i.e. not medium and heavey trailers!)
[quote] from section 4 definitions
Very light trailer
TA
O1
1 July 1991
Nil
Light trailer
TB
O2
1 July 1991
Nil
[/quote]
Now something else that shows these ARDs aren't relating to your situation.
They talk about 50 Mm dia tow pins (and 50 mm dia tow balls) and 127 mm diameter tow balls!
You ever seen a 127 mm dia tow ball?
Man thats 5 inches in diameter about the size of a grapefruit!
Thats a
pic of a 75 mm diameter towball rated to tow 4.5 tonnes according to the stamp on it and its partner I carry as a spare.
How many tonnes is a 127 mm tow ball rated too?...and they are talking here about very light and light trailers?
You see these ADR's and the heights being touted aren't referring to your MC class 4wd tow vehicle.
Tell you what tho - when you look at that draw bar of mine - if you go to your local C/van
shop and look at the Hayman Reece etc brands just like it - you'll see some that are actually tow ball height adjustable!
Yes - just like your draw bar has a 13 mm pin in a hole - the height adjustable right angle 2 inch solid barstock steel drawbar also has a couple 13 MM holes and high tensile locking pins to adjust the ball height!
So essentially by using the right angle draw hitch you can reverse it to make the adjustment either up or down from the existing height - by just reversing the ball mounting to account for which way you insert it into the tube (either up or down) then you can raise or lower the ball coupling section with the two locking pins to whatever laden height you desire!
(you can attain about 2 feet of total raise height or lower height using this method.
This way - whatever the weights and scales
police tell you when they pull you over is the proper legal height - you just measure the existing laden height and figure how much you need to go up or down. Then drop your jockey wheel - to support the weight of the trailer, leave the safety chains on - and wind the trailer up or down so theres no load on the towbar - and adjust your ball height up or down by the required measured amount to comply and then re attach!
Which weights and measures copper is going to charge you for towball height - if your willing to adjust it to whatever he says on
the spot!
I'd bet you my left nut that - he couldn't produce any ADR that specified a height - to quote you letter and verse what was required.
About all they can do with their scales and tape measure is tell you what overall load your towing - and the towbar downweight!
Long as those are rght and your towing level or slightly nose down - they won't even query your towball height!
Guess what - neither will your insurance assessor!
How could an insuarance assessor determine after an accident what the laden or unladen towball height was anyway - the van by then would be uncoupled and the load off the tow vehicles springs etc - he has no way to tell those laden perameters after the fact!
It is my belief - you are asking the public service transport people to specify something that falls outside their ADR scope for your van and vehicle in order to be covered for something no insurance assessor could measure or determine accurately after the event of an accident anyway!
As others have said - I reckon - your just whippin a dead horse- no matter what you achieve it will still be a dead horse at the end of the day!
Try and remember - these guys you want answers from aren't the sharpest
tools in the shed.
Who told you (what verifyable and reliable source) in writing that insurance asessors are denying caravan towing accidents claims based on unladen vehicle towball to road heights from the ADR's?
Remember - even the ADR's quoted above are for unladen vehicles. Once you attach your van it is no longer unladen - the specified heights are MINIMUMS - to STOP tow bar supp[liers fitting towbars to vehicles that are so low thery drag on the ground when the vehicle is laden.
I think you have this bull bye the wrong horns maybe.
It's a paradoxical discussion based on an initial false premise IMHO.
The usual problem with producing a hypothesis based on a "false" premise is a paradoxical result.
For example:
(1) All dogs have four legs,
(2) All four legged animals are cats.
Therefore:
All dogs are cats,
AND/OR
All cats are dogs!
Which premise is false?
I don't believe insurers are denying accident claims to 4wd owners towng vans due to some unprovable reference to a ADR that apparently doesnt exist specifying minimum road to tow ball unladen height specification, for Class MC (4wd Passenger vehicles).
Don't let it eat you up - even geniuses get it wrong sometimes!
Einstein was one!
With the Special Theory of Relativity, the resulting paradox, was called the "twin paradox" (google it - fascinating) along with several others which were discovered later.
The thing is today even a 14 year old kid in high school can disprove Einsteins special relaivity theory E = MC ^2
C being the universal constant speed of light limit MEASUREABLE velocity in our universe!
186,000 mi/sec. (3 x 10^8 meters per second).
Those big numbers tend to confuse average mathematicians.
Lets look at a simpler figure for sqaure roots ` 4
Ask most people here whats the suare root of 4 and most of us will answer 2
2 squared equalls 4 - everyone knows that just as everyone in Einsteins time knew that the speed oflight squared was 9 x 10 ^ 16 meters per second or (3 x 10 ^ 8) squared! (or back in my day 186 000miles per second).
Trouble is - the 14 year old kids on this
forum - who payed attention in year 9 math class - will tell you,
That the square root of 4 is +ve 2 and -ve 2
Yep - when you square a negative you get a positive result -something all the scientists conveniently forgot when Einsteins un peer reviewed paper on special relativity was published because he had recently won a nobel prize for his peer reviewed paper on the Phototelectric effect, and was thus considered a scientist without peer!
The fact is that E = MC^2 was a false premise which led to a paradoixical result (the afforementioned twin paradox).
Just as your original post was based on a false premise and has you chasing a paradoxical result.
Facts are
The ONLY velocity for the limit velocity for light in our universe that makes E = MC^2 is infinity (Immeasurable) because only infinity squared + infinity!
Only Infinity gives us a result for lightspeed C that is not paradoxical in E = MC ^2!
So - back to your quest.
Your orignal hypothesis about insurance assessors = false premise above number (2) "All four legged animals are cats" and has led you to a paradoxocal result.
Thats how I see it!
Quit whippin the dead horse & the paradoxical cat!
Just take that van somewhere and enjoy it, life is too short!
345808
Follow Up By: Flywest - Sunday, Jan 25, 2009 at 03:04
Correction
because only infinity squared = infinity!
Phat Fingers syndrome! ;o)
613823
Follow Up By: jdwynn (Adelaide) - Sunday, Jan 25, 2009 at 08:51
FW, marathon post! Having a bit of trouble sleeping LOL. You make lots of good points.
My Trol is so strong in the back end that I couldn't lower it on the road if pulled over by
police (when we had a van that is), but like you I also wondered what an insurance assessor could prove after an incident.
I guess problem though is desire Kev has to do the right thing and anxiety of knowing not all square when you're a long way from
home. Remember Cruiser driver from SA (?) pulled over in Qld cos he didn't had (removable!!) rear seats in his vehicle and the trouble it caused. cheers
613831
Follow Up By: Member - Kevin J (Sunshine Coa - Sunday, Jan 25, 2009 at 10:12
Thank youFlywest. I'm sorry to have put you to so much trouble and taking so much of your time in writing the above. This was not the intention of the original post. I may have ommitted to advise that I do not claim to be an expert on these matters and as I did state I was and am seeking the input of knowledgeable people in order that we - the people towing caravans - can protect ourselves from those who have the position and ability to cause us undue financial pain and mental anguish by using uncrossed "Ts" and undotted "Is" to bring about our demise in the event of an accident.
With my limited knowledge I do know that a lot of the Standards are written in a way which only makes the situation more confusing however I do understand that there are large sections which are referring to Fifth wheelers and what I would term Industrial trailers. so when an issue relative to 127mm circumference balls is mentioned I ignore that reference. We are talking about MC category only.
I also have no doubt that the
police across the country are not in a position to question the setup of say my combination and to be frankly honest any reasonable thinking expert would agree that it is what it should be. Level.
This exercise is not about me or my rig but rather an effort to create awareness of what can be a major difficulty for others and to mobilise the caravanning fraternity to pressure for changes in the WRITTEN regulations to what is sensible.
You may make your own decisions. That is not for me to dictate.
Thank you again for your contribution.
Kebvin J
613837
Follow Up By: Flywest - Sunday, Jan 25, 2009 at 12:48
Trouble sleeping - yes indeed!
This shows the hayman Reece Height Adjustable tow hitch with load levelling head!
You can see that it is "height adjustable" with all those holes in it and the ability to invert it in the receiver if required!
Theres a reason Class MC (4wd passenger) vehicles are excluded from the standard.
You see it is possible to have these "engineered (until recently) for
suspension upgrades with kits up to 6 inches or more of lift!
For this reason - if the ADR's specified a Max heght above road for the class MC vehicles - any lifted vehicle compliant under it's ADRs with a raised suspenson wouldn;tcomply to the tow ball height adrs.
It simply isn't possible to specify tow bal height in this class of vehicle.
Remember that a lot of army trucks like Unimogsetc also rfall into this category and also tow woth pintle hooks etc etc
Those doing the ADRs realise that it isnt possible to specify a max tow ball height for this class of vehicle - also this calss of vehicle can have 5th wheeel hitches mounted in the tray of utes etc again a problem for tow ball height regs.
I can't see you gettinga result on this one!
613846
Follow Up By: Member - Kevin J (Sunshine Coa - Sunday, Jan 25, 2009 at 13:19
Thank you again however while I agree that MC category with an Off Road spec van cannot possibly meet the AS4177 this is the entire purpose of this exercise.
The entire problem is that when the Standard was last ammended Category MC was included in the height limits. eg MA MB & MC all must comply with the 350mm to 460mm Maximum standard.
We have this on authority.
The problems are how do we live with the rules now and what can be done to change the rules.
Please don't continue to tell us what we know. The limits are wrong for Category MC
This issue has now gone to a back page so that's where this discussion ends from my point of view.
Kevin J
613851
Follow Up By: Flywest - Monday, Jan 26, 2009 at 02:20
No worries Kev,
[quote]
We have this on authority.[/quote]
The amended ADR isn't available online?
Maybe you could ask someone to fax you a copy then?
I can't find any mention in the online links of any amendement to the ADR's that includes Category MC - but would be happy to be - so corrected!
As you might see above - should that prove to be the case -the depicted adjustable height ftaw bar would allow you to meet that spec.....so problem solvered - you could comply and be totally legal!
I can't see a problem...either way.
Finally the Dead Horse & Schrodingers Cat (google is your friend) can rest in peace, bless their souls! LOL
613945
