Wind generator
Submitted: Thursday, Aug 14, 2003 at 16:58
ThreadID: 6569 Views:3862 Replies:10 FollowUps:3
Has anyone ever thought of putting a small wind generator on the roof rack to power a deep cycle battery for the fridge? I did a search and seems no-else has been silly enough to suggest it. Any ideas?
Reply By: Luke - Thursday, Aug 14, 2003 at 17:11
hey - great sounding idea...no idea about this method of generation though - wonder what sort of charging current they can generate - and how much etc......I guess only disadvantage that comes to mind immediately would be the fact that it would only work when vehicle is moving - thereby making it not terribly as solar for charging a dead vehicle battery if the car can't be started.
....worth poking around a bit and looking into though....
AnswerID: 27907
Follow Up By: Member - Moggs - Thursday, Aug 14, 2003 at 17:41
Jimbo, I had the same idea some time back and investigated putting a series of generators acroos the front of the roofrack where the current wind deflector sits. In the end I came to the conclusion that it would not achieve any more than the current alternator in the vehicle, and in fact with reference to increased wind drag, the alternative of fitting a larger alternator is more viable. At least I feel better now that someone else thought along the same lines!Moggs ( Normanhurst NSW)
FollowupID: 19264
Reply By: Member - Geoff - Thursday, Aug 14, 2003 at 17:58
Jimbo,
How do you feel about a 1.5m dia propellor on the roof, this will possibly give the required watts.
cheers geoff.
AnswerID: 27911
Reply By: ExploreOz - Thursday, Aug 14, 2003 at 18:09
Now Moggsey! Surely we can't be the only silly buggers on this planet. A while ago, I replaced the fan/motor assembly in our free-standing Eureka fireplace. Lovely assembly fabricated out of galvanised sheet metal; two barrel fans on bearings; a little motor in between them (stuffed motor and hence the replacement.). Now, somewhere back in history, someone told me if you pass a current through a wire wound around a nail which is mounted inside a permanent magneta, then the nail will and spin : an electric motor. Similarly, if you can find a way of spinning that armature, then electricity is generated : a generator ... be gentle with me! If I mounted that fan assembly on the roof, would it spin the motor and make electricity?! :-) ... I gotta get a hobby! This is embarrassing!.
AnswerID: 27913
Follow Up By: Mick - Saturday, Aug 16, 2003 at 23:33
That's how it works!! Pretty basic!!
FollowupID: 19479
Reply By: ExploreOz - Thursday, Aug 14, 2003 at 18:17
1.5 m propeller, eh? But but what if you had a six foot length of 6inch poly pipe with a great long barrel fan mounted in it? Would a really long barrel fan somehow equal a really wide blade?
AnswerID: 27915
Reply By: Jimbo - Thursday, Aug 14, 2003 at 18:26
Moggs, what sort of generators were you going to use? Where sourced? I dunno why but I've just got this mistrust of fiddling with the car's electrics. Feel safer with the auxiliary power system separate from the car's system.
AnswerID: 27920
Reply By: joc45 - Thursday, Aug 14, 2003 at 18:47
Hey guys!!
You already have one of these thingys - the fan behind the radiator is connected to your alternator, and when you drive along, the wind thru the front of the radiator helps turn the fan, charging the battery, and also helps the load on the engine, saving fuel!!!
Seriously, marine stores flog small wind generators for yachts, which could be used to charge batterys where there is plenty of wind, but not much sun for solar panels. They're not all that big.
I recall the old Dunlite wind generators, with 1.2m blades (2.4m dia) used to put out a whopping 120A at 28v in a good wind, but a bit impractical for a camping outfit.
Gerry
AnswerID: 27923
Reply By: Jimbo - Thursday, Aug 14, 2003 at 18:55
Geez, Greg. You're no fun at all. Does that wind thru the radiator trick work when you've got a radiator fan that only comes on when the egine gets hot?
AnswerID: 27924
Reply By: greenant - Thursday, Aug 14, 2003 at 19:07
Why not a mast and sail on the roof to help with fuel economy when you have a following tail wind
AnswerID: 27928
Reply By: andy - Thursday, Aug 14, 2003 at 20:12
could put a wind generator into the seats of some of the forum readers. The amount of beer fartz, BS and crap coming out of their butts would easily power an engel
AnswerID: 27938
Reply By: Member - W.Wallace - Thursday, Aug 14, 2003 at 20:51
You could always point it skywards & drive really fast, & just "helicopter" your way over some of those dunes! ;)
AnswerID: 27947
Follow Up By: wazza - Friday, Aug 15, 2003 at 15:52
You would look like that guy in the Gyrocopter on Mad Max II
FollowupID: 19389
