sterilising water tank
Submitted: Saturday, Aug 16, 2003 at 21:16
greenant
I have an off road camper and want to add iodine to the
tank to sterilise the
water that wont drain out of the
tank when not in use. Does anyone have any ideas on amount I should use. There is tablets available but very expensive and I have been told to use iodine but not told how much to use has anyone any ideas
Reply By: nugget - Saturday, Aug 16, 2003 at 22:15
greenant
What I'm about to say may sound like I've lost my marbles but I do believe that red cordial when added to
water will after a while sterilise it (kill bacteria). I dont think concentration levels are anything like what you'd use when making a drink, (imagine cooking the veges or having a shower in red cordial!) to the point where it wouldnt be noticed and whats more very cheap. I'm sure I'm going to cop abuse over this one but hey I dont mind taking the heat off Truckster for a while.
28127
Follow Up By: Ed - Saturday, Aug 16, 2003 at 23:00
No abuse from me nugget....
Heard about this one years ago...
specifically, it's RASPBERRY cordial, containing at least 35% fruit (raspberry) juice...
Go to www.google.com.au , type in "raspberry cordial" & hit the "search" button.. on the 1st page, there are a couple of references on this very subject...
He who can, >>>> Does!
He who cannot, >>>>Teaches!
Ed. C.
19476
Follow Up By: Hugh - Monday, Aug 18, 2003 at 23:12
Nugget,
The rasberry cordial works for this sort of thing. We always take it on trips to Bali as it stops Bali Belly - works too. Even the Dept. foreign Affairs & Trade web site refers to this practice.
Hugh
19655
Reply By: Member - DOZER- Saturday, Aug 16, 2003 at 22:46
Gday
Bicarb soda a teaspoon or two in some
water in the
tank will do the trick. Flush it out with a few tankfulls of
water afterwards to get the taiste out.
Andrewwheredayathinkwer mike?
28129
Reply By: Mick - Saturday, Aug 16, 2003 at 22:59
Chlorine will also kill bacteria in
water - it's the most commonly used anti bacterial treatment for pools and
water supplies. However, if your
tank is black plastic, and therefore the
water is not exposed to light, bacteria will not grow. I've had my van for 25 years and simply top up the
tank before a trip and the
water is always excellent. Only problem I've ever had was after filling it using a new hose and the
water tasted of plastic! The secret is no light - as in underground caves where you'll find crystal clear
water.
28132
Follow Up By: Tuco69 - Saturday, Aug 16, 2003 at 23:39
I agree with Mick.
The black tanks do not allow algae to grow - however if you have clear inlet or outlet or vent hoses - these will let it grow and get into the system.
I have all three hoses on both tanks on our camper in black poly. Never have a problem. Same with the
tank under our Toyota Surf.
If you do have some clear hose that is difficult to replace with black, then just lag it with split loom tube or some other black material of some sort. Just make sure that the light can't get at the
water - anywhere.
19480
Reply By: basecamp15 - Sunday, Aug 17, 2003 at 09:18
Chlorine is definitely the way to go.
Although you may have a dark
tank to prevent growth, it's possible the
water you put in is contaminated with bacteria (not algae).
It can be very tricky getting the right concentration though.
You want a free residual of around 0.5 mg/L. Household bleaches (domestos etc) have a concentration of around 5%, that equates to 50 000 mg/L. Gives you an idea of the dilution factor.
If it's only to keep the dregs clean when not in use like you say it can't hurt to add a bit more (one squirt)
28159
Reply By: jonny knowalittlebit - Sunday, Aug 17, 2003 at 11:15
try miltons anti bacterial solutions it can be gottin from shopping centre. alls it is is very week chlorine.
i use it every now and again in my camelback bladder one cap for 3 litre is all i use. dont know if thats correct or not but it does the job.
28170
Reply By: ToyMotor - Sunday, Aug 17, 2003 at 16:23
Iodine is a bit extreme! Potassium Permanganate is the go (Condy's Crystals). Can also be used as a cheap method of sterilising unknown
water supplies - add until colour just becomes perceptible in the
water. Also good for horse's hoof infections!
28197
Follow Up By: Mick - Sunday, Aug 17, 2003 at 22:34
Don't tell me you've come across a cure for the disease that horse's hoofs get!!
19551
Follow Up By: Member - Shawn - Wednesday, Aug 27, 2003 at 13:55
LOL, very goodKeep your powder dry
20420
