AnswerID: 356823 Submitted: Sunday, Mar 29, 2009 at 09:18
oldfart1953
replied:
Hi John,
You have purchased a great radio, I have an NGT myself & thet are a great unit & very easy to use once you have mastered the keypad on the hand piece.....if I can,.. anyone can.
Aerial positioning... I believe in
Victoria & SA the powers that be are against the mounting of the antenna on the front of the vehicle...possible obstruction to vision. Here in NSW as already mentioned as long as it doesn't protrude forward of the bullbar you will be OK. In NSW there are State Government vehicles running around with aerials mounted on the front bar...so until they get rid of these vehicles the coppers cant book you, here in NSW at least. Having an
HF radio fitted of course you are going to be travelling, touch wood I havent been questioned or booked whilst driving interstate withe aerial mounted on the front. I currently have a LC 200 series with the aerial mounted on the bullbar, on the same side as SWMBO. Well didn't she perform when she saw it mounted there....I don't want that big bulls dick in front of me....but very quickly she got used to it being there.....it's as it you see right through it. (I also have the phone & UHF aerials mounted on the bullbar)
With the aerial you will have two leads going to the aerial & one earth strap coming from the aerial. The earth strap is nearly a meter long & is designed for universal mounting it will have three positions along the strap where you can earth it out In my first vehicle that I had this radio fitted to (LC100) I earthed it out at three points (overkill I know) BUT I cannot over stress the importance of having a good earth. To enhance the fitment of the aerial astheticly I fitted a length of heat shrink over the cables & earth strap (base of aerial to where it goes through the grill). Pay particular attention when sealing the leads to the aerial with the special tape supplied you don't want moisture/dirt getting into the pug & sockets
A suggestion also don't cut any cables or leads during the installation, coil up neatly any excess cable length as you may need it in you next vehicle when you install the radio into that vehicle. As mentioned in a Alistair's post earth out the cradle that supports the 'base unit'. I have always hard wired the power lead directly to the battery.
The remote speaker I mounted under my seat tied on with cable ties to the seat springs....works for me.
When driving/using the vehicle leave the radio on 'scan' so that you can be reached by selcall if need be.
You possibly have already considered a network to join?...if not have a look at www.hfradioclub.com.au a very friendly & active group (yes I am a member).
In closing enjoy your radio (participate in sked's practise make perfect) & MAKE SURE your partner also knows how to use the radio as well!!!
Make sure when you drive into a servo or bottle
shop you don't take out a row of fluro lights with the aerial....very embarrassing!!!
Tony H
Hunter Valley
Reply 4 of 5
