Site Search
Section Image
2nd water tank position
Submitted: Sunday, Apr 19, 2009 at 14:08
Seakarvan
Article Overview - Water Tank
Water storage is a critical issue for all four wheel drivers. Not only do you need to carry large amounts of fresh water, you also need 2 alternate supplies in case of contamination from one source. View Full Article...
Hello Thrillseekers,
Because of water quantity issues on our last trip, I'm thinking of a 2nd water tank. We have a 17 footer with about 60 litres.
Is there a popular brand 60L plastic tank to buy? and would it be positioned forward next to existing tank or rear of the axle?
Also, do the much travelled generally link both tanks or set up separate systems?
Seakarvan
ThreadID: 68010 Replies: 6
Views: 789 FollowUps: 1
AnswerID: 360342   Submitted: Sunday, Apr 19, 2009 at 14:43
Sir Kev & Darkie replied:
I would position it to the rear of the axle to balance the load and have it on a seperate system so if by chance you get a bad load of water it wont contaminate all your water.
Cheers Kev
The Pyrenees
Click Image to Enlarge
I am NOW living in Chinchilla, the Australian Melon Capital ;)
Reply 1 of 6
AnswerID: 360343   Submitted: Sunday, Apr 19, 2009 at 14:58
Member - 1/2A replied:
I have two 120lt water tanks in the Vision one fwd of the the axle and the aft of the axle. I always fill the aft tank first and thus reduce the ball weight, if I don't require the full 240lts.
Morning tea far North Queensland
Microsoft is like an air conditioner when you open the Windows it stops working!
Ubuntu 9.10 Linux 64 bit.
I don't support the M$ Empire!
Reply 2 of 6
AnswerID: 360344   Submitted: Sunday, Apr 19, 2009 at 15:03
Motherhen replied:
Hi Seakarvan
We have 4 x 80 litre poly tanks under our 18' caravan. You should have plenty of room for more tanks. I cannot comment on placement as this would be specific to your van, and i am no expert here either.
One is for drinking water and has a separate pump and tap. We can last for up to two weeks without refilling. Do not link the tanks. A previous owner had linked two of the tanks, and we suffered stone damage to a small trickle irrigation type on the hose between the two tap and the contents of both tanks were lost - when we had refilled with lovely fresh water at Kununurra to head into the Tanami.
There are different types, and also the poly on some is thicker. Some are long flat tanks (probably like you have) which need to be slung with something onto the frame - either a guard or straps. Others screw or bolt directly without an unslung guard.
Near the Stuart Highway NT
Home to reality - The dream trip is over
Reply 3 of 6
AnswerID: 360384   Submitted: Sunday, Apr 19, 2009 at 17:54
PeterInSa replied:
You do not mention whether you have a single axle or dual. If its a single legally you can only load your van with 280Kg of water/gas/gear and food, most dual can go 400Kg or more. So with another tank full of water thats 60Kg or 44Kg of food/gear that you cannot carry, if you are on the limit.
As mentioned above it depends on the setup of your van and how you load it eg a front kitchen probably has more weight on the towbar than a van with a double bed in front. If the van wheels are well to the back the towbar could also be heavily loaded so 2nd water tank should be behind the axles.
We have 3 tanks in our van 2 are linked together in front of the axles and one at the rear. I can fill the linked units together or just the one closest to the axle and have the controls to isolate them as well. The linked units have one gauge and the rear a separate gauge as well.
If you put in a separate tank is probably easier to use the existing fill inlet and underneath the van just have valves to direct the water to either tank.
Would definitely use a stone shield as the tank you install will probably hang down lower than the tank that came with the van, your van chassis was probably made to fit the tank.
we use our third tank for drinking water and connect to a hand pump, so do not annoy our neighbours if we pump out a glass of water at night. But of course with valving you could plum your second tank into the vans water system.
You could also consider carry 3x 20Lt containers of water in your tug, to get over the install.
Reply 4 of 6
Activities Index
Horse Riding On The Beach For Two Horse Riding On The Beach For Two
Great Ocean Road - VIC
Horse riding along the beach with horses that suit everyone's ability.
Seafood BBQ Cooking Class - VIC Seafood BBQ Cooking Class - VIC
Melbourne - VIC
Are shrimps on the BBQ more your style?
The Real Outer Barrier Reef Experience The Real Outer Barrier Reef Experience
Cairns and Tropical North QLD - QLD
An experience of a lifetime where we'll take you to an underwater world that's a dazzling kaleidosco
Pamper & Pole Dancing - Ultimate Hen Pamper & Pole Dancing - Ultimate Hen's Party
Sydney - NSW
The Pole Dancing & Pamper Package is the perfect experience for a memorable hen's night.
Book Now - Things To Do
AnswerID: 360445   Submitted: Sunday, Apr 19, 2009 at 22:00
Simon C replied:
Don't know where you are, but CAMEC in Brisbane have a vast range of tanks in different sizes, outlets/inlets, etc. I purchased a 90 litre tank and hoses for my Goldstream Storm Camper at Christmas and it cost me around the $120.00 mark all up. Only thing I could not purchase was the tank straps. CAMEC do not sell them. I mounted it forward of the axle, (the original tank is mounted rear of the axle), and I noticed no real differnce in the towing and handleing of the camper when the tanks are full. I still have to sort out the filling of both tanks as I tried to cheat and use the same filling hose and 'T'd"in the it for the second tank, and it doesn't work (properly filling them).....
Reply 5 of 6
FollowupID: 628223   Submitted: Sunday, Apr 19, 2009 at 22:36
Member - Matt H (SA) posted:
Simon C,
Drop me an email via my member profile, I too have a Goldstream Storm Camper and would like ask you some questions about accessories, etc.
Cheers, Matt.
AnswerID: 360493   Submitted: Monday, Apr 20, 2009 at 10:17
Seakarvan replied:
Thanks for the down to earth advice guys. My limited Van experiences so far have shown that even with all the rain, water quality is an ongoing and increasing issue. A formula of water litres to days can be subjective. But common sense hopefully will prevail.
I like this refreshing formula for travel survival:
On the Cape (York) distance is locally measured by the Carton eg Bamaga to the east coast crabbing = carton and a half in the dry. Klms never seemed to apply. Just "Carton" and time combo.
Seakarvan
Reply 6 of 6
