FollowupID: 629628 Submitted:
Monday, Apr 27, 2009 at 15:49
Shaz & Col posted:
no these transformers usually only put out about 12.8 volts which it not high enough for a battery to charge properly,it should have a spec label on it and this will tell what voltage it puts out.
if you are not sure call jayco and check before hooking a battery up.
battery to use would be a sealed deep cycle 100a/h, set the vehicle up with a dual charge system through an anderson plug set up etc.
