Falcon Hydratrac diff
Submitted: Wednesday, Aug 27, 2003 at 11:57
ThreadID: 6862 Views:2570 Replies:4 FollowUps:0
Hi all i know its not a four wheel drive but it gets me around albeit a bit more cheaper and reliable now my question is oil what oil should i be putting in the diff as after 140 000k she is black and dirty. Ford dont sell the oil but the service department can change the oil for a fee.
Steve
Reply By: pathfinder - Wednesday, Aug 27, 2003 at 12:13
unless the lsd in the falcy is as durable as that in a Patrol, I would be surprised if you don't need a complete diff service after that many kays and given the "quality" of the oil - e.g. replace clutch packs (if it has them) etc. One way to check this is to jack one rear wheel off ground to see how freely you can spin it. A really strong lsd should be able to drive over a brick with the other rear off the ground (i.e. even though one wheel is "slipping" the other wheel should still be getting some drive to it. If you decide to just change the oil, any hypo lsd oil should do...
AnswerID: 29306
Reply By: Member - DOZER- Wednesday, Aug 27, 2003 at 18:20
Gday Steve
Im only guessing, but if you have a Hydraulic or viscous diff, as in the longreach uterus,the oil in the viscous part is not replaceable (sealed unit) and the oil in the diff should be std gear oil.
What sayeth the owners manual?/workshop manual/ ever thought about the reference library to have a look?
Andrewwheredayathinkwer mike?
AnswerID: 29344
Reply By: kezza - Wednesday, Aug 27, 2003 at 20:02
Im amazed but we have an XF falcon with a Limited Slip Diff that still works fine after 350,000klm Im not joking! but Ive been running a penrite limslip diff oil in it since it had 195,000 km Just make sure you a good LS specification Oil I cant help but reccomend the penrite as thats all Ill use these days.
No I dont own shares in the company.
Kes
AnswerID: 29355
Reply By: Steve from Drive Systems Victoria - Thursday, Aug 28, 2003 at 09:50
Penrite Limslip 90/140 available Autobarn etc. You hassle will be getting the oil into the housing, unless you can borrow a pump.
AnswerID: 29415
