Hilux Radio Wiring Diagram
Submitted: Tuesday, May 12, 2009 at 17:20
ThreadID: 68756 Views:41377 Replies:4 FollowUps:6
Hello all
Have a AM/FM radio out of 97 Hilux wanting to use for a new project has 8 wires from gen toyota plug has anyone got any info
please have done a google but only come up with radio/tape and cd players wire colours are
light green
blue
pink
purple
brown
grey
blue
green
Oldpop
Reply By: Member - Graham H (QLD) - Tuesday, May 12, 2009 at 17:41
What make is it toyotas used to be Fujitsu Ten radios perhaps look for a name and email the maker .
Thats what I did with one I got out of a Commodore.
AnswerID: 364500
Follow Up By: oldpop - Tuesday, May 12, 2009 at 17:55
Thanks for that will give them a try
Oldpop
FollowupID: 632169
Reply By: Lex M (Brisbane) - Tuesday, May 12, 2009 at 17:50
Does this help?
Image Could Not Be Found
AnswerID: 364502
Follow Up By: oldpop - Tuesday, May 12, 2009 at 17:58
Lex M
the ten pin plug looks the same but wire colours are a bit different
Oldpop
FollowupID: 632170
Follow Up By: Lex M (Brisbane) - Tuesday, May 12, 2009 at 18:09
I have a radio out of a 96 which agrees with this diagram. Be aware the plug as drawn is the plug in the dash which plugs into a toyota radio.
Check with multimeter if you have any doubts. Pin E,F and G all connect to the case on mine.
FollowupID: 632175
Follow Up By: oldpop - Tuesday, May 12, 2009 at 18:22
All wires check out OK except pin G mine is brown not black
will check with multi meter and see what happens
Oldpop
FollowupID: 632177
Follow Up By: Member - Phil G (SA) - Tuesday, May 12, 2009 at 21:09
Brown is earth.
I fitted a radio to a 1997 80series radio last weekend so its still fresh in my mind. I followed the wiring from the Prado which was from this site.
FollowupID: 632211
Follow Up By: Member - Phil G (SA) - Tuesday, May 12, 2009 at 21:11
Whoops! Heres the rest to go with the above:
A1 = Front Right pos = light green
A2 = Front Left pos = Pink
A3 = Accessory pos = Green/Red trace
A4 = Pos from battery = red but I ran a separate lead direct from battery
A5 = Front Right neg = Blue
A6 = Front Left Neg = Violet
A7 = earth = brown, but I ran a separate earth to a 6x1mm bolt inside the dash.
A8 = Antenna = Black/yellow trace
A9 = Amp + = pink/blue trace = not usually required
A10 = ???? lights - not usually required
B1 = Right Rear pos = red
B2 = Left Rear pos = Black
B3 = Right rear neg = white
B4 = Left rear neg = yellow
FollowupID: 632212
Reply By: rags - Tuesday, May 12, 2009 at 21:37
HI you will find that there will be a harness available from this company
http://www.aerpro.com.au/list.php?cat_name=harnesses&cat_no=10
available from jb hi fi ,jaycar,supercheap ,etc
used them 3 times for 2 toyotas and a ford ,makes life easer
Russell
Site Link
AnswerID: 364578
Reply By: oldpop - Wednesday, May 13, 2009 at 07:49
Thanks guys
Got all sorted now
Oldpop
AnswerID: 364607
