AnswerID: 29816 Submitted: Monday, Sep 01, 2003 at 21:19
Bne Lad
replied:
Bazza,
Don't forget, if you connect anything to your battery direct, it needs to be fused.
The last thing you want, is your nice new heavy guage wiring rubbing metal and causing a fire. Use a suitable fuse according to the guage of the wire. Formula used is 3A per 0.5mm of wire.
I concur with the cigarette lighter outlets, they don't provide an adequate connection. The Hella plugs are very good and capable of high amp continuous running.
Cheers Mate.
Steve
Reply 3 of 5
FollowupID: 20887 Submitted:
Monday, Sep 01, 2003 at 21:49
Tuco69 posted:
The Hella Din sockets and plugs at http://www.hella.com.au/ are rated 8Amp @ 12V or 4Amp @ 24V.
The beauty of this design is that once pluged in - the connection is positive and not likely to accidentally become disconnected like the cigarette type sockets can.
Tuco
