AnswerID: 1910 Submitted: Friday, Feb 01, 2002 at 00:00
jeremy
replied:
Scott, I own a 95 TDI Discovery that i run tag-a-long
tours in, and i also work in a OL store using and fitting
suspension on all makes, OE spring are most under done and thats why the diso went to a set of sway bars, the best option is a set os 2 inch raised coils most aftermarket one are really good (most come out of same factory)As for shocks, Billies, Koni's all come highly recomended for the landies and you cant go past the foam cell shocks of today, Rancho and Tough Dog do a great foam cell that will give i think the best all round ability, definatly in genral comfort, I run Koni's which are adjsutable and have used billies which are great but can seem a little firm. With the H/D coils you can throw away your sway bar if you like ......rides just fine coz the springs are strong enough to handle it, just remember in real rough stuff this will give you greater wheel travel but can make shockers bottom out more (shocks are the only thing stopping diff)this is only the case in extreme 4wd work. as for poly airs.... i have run them in 2 vehicles and never had much sucsess with them !!!....but they are a good thing, our training with them are that they are more made for the odd accasion when you need to tow or load the back of your vehicle and the Poly-airs assist the spring do its job !......they are not made to fix badly sagged springs or stuffed shockers......poly-airs also restrict the coils from moving in its natral way and can make a harsher ride when pumped up hard......... i feel that if you get the correct springs in the first place you will not need them......unless you intent to tow a huge van on an odd occasion ????
I have done etensive work with landrover suspensions so don't hesitate to email me if you like !
Hope that all helps, Jeremy
Check out my Web Site www.murraytrek.com.au
Reply 8 of 8
