AnswerID: 30032 Submitted: Wednesday, Sep 03, 2003 at 20:50
Frankenstein
replied:
60 Series leak oil everywhere!. If you have one that doesn't leak oil then you probably need to put oil in it. That said the vehicle test is the best thing you could have done.
Here is why...
Engine rebuild - $6500 - $10,000 (diesel)
Gearbox $1500 - $3000
Transfer case $1500- $3000
Diffs $1500 ea
Don't replace the transfer case or else you will probably get one that has done 300,000+ K's. The seals on the propeller shafts are the most common and very easy to replace. Mine was leaking out of the transfer case gasket (between the two halves) A job requiring $40 parts and about 5hours labor.
The landcruisers have separate oil in the transfer case and the gearbox and an oil seal inbetween. Because the transfer case has an oil pump in it, the xfer case oil finds its way into the gearbox (up hill) - this is a real common fault. Keep a constant eye on the levels, if you notice the gearbox is over full and the xfer case getting empty fit a bypass hose kit between the two filler caps to drain the oil back down again (this usually happens after 250,000 K's). You can replace offending seal (at great expense) only to have the problem back in 6 months.
Clutch boots and seals are just minor maintenance, just get used to it you will be forever putting your hand into your pocket as long as you keep driving it.
Spring shackle rubbers, oil seals on the front of the engine, diffs and gearbox will need to be replaced as the vehicle ages - the genuine oil seals from Toyota (about $17 ea) have external dust seals on them which prolongs the life of the seal - go for these if you can.
They are a great truck and very capable, many of the mechanics reacon they are one of the best out there.
Frankenstein is the name of the truck (blame the kids!)
Reply 3 of 6
