G60 - What year?
Submitted: Wednesday, Sep 03, 2003 at 20:48
ThreadID: 7017 Views:2248 Replies:3 FollowUps:0
I resently purchaced a G60 patrol flat tray and plan to restore it. Unfortunately I have no idea what year it is as it does'nt state it on the plate under the hood and I have no rego papers to say so. It appears to have the original white paint on it (dont know if that means anything). It is also fitted with a ford xe motor and transmision, so I get any details off the motor. Can anyone suggest any way to find out?
Reply By: Voxson (Adelaide) - Wednesday, Sep 03, 2003 at 22:32
yes... you will find that the factory writing on your side windows (normally on most cars near the lock button) will have a little dot above one of the letters which signifies which year the window was made which in turn gives you a good idea when the car was built. The way to read the year,,,,, is count the amount of letters in that the dot appears above....and if you know the decade of the vehicle you will get the approx build date......so if the dot is above the third letter it would mean that the window is (1983 for eg)............but i cant remember whether or not you count from the left or right....i would say Eric on this forum would know the answer to that or ring a crash repairer,, they know also.......
Regards......._____________________________________________
AnswerID: 30051
Reply By: Truckster (Vic) - Wednesday, Sep 03, 2003 at 23:52
Has it been registered before? Use that number plate to find out.
It should state it on the compliance plate, thinking they wouldnt let that go far!
also have a look at
http://www.ebroadcast.com.au/ecars/Nissan/60.html
AnswerID: 30060
Reply By: Willie - Thursday, Sep 04, 2003 at 18:07
You could try nissanpatrolg60club@yahoo.com
The G60 was manufatcured from 1960 to 1979. If it does not state under the hood what yearit is pre 1974.
I drive a G60. If you need other info on G60(I have a Factory Manual) contact me through my website www.kempen.id.au
Willie
Click on the photo below to see a pic of the G60
Never a dull moment
AnswerID: 30121
