AnswerID: 375849 Submitted: Thursday, Jul 23, 2009 at 17:58
ABR - SIDEWINDER
replied:
Carl your solar regulator would need approx 8V to activate so that may not work for you.
The car should bring the voltage up to a point where the solar regulator can take over but you actually need a good charger to try recover the batteries. (They may not recover) The cars regulator will not allow you to push the 14+ volts into those batteries that they need to re-charge.
I suggest you buy a good charger and if that does not work you will need new batteries. Look for one with PWM or a Desulfate step in the program.
Derek from
ABR | ABR - SIDEWINDER |
Reply 5 of 7
