Hot Shower install help
Submitted: Wednesday, Jul 29, 2009 at 07:39
ThreadID: 71047 Views:3830 Replies:5 FollowUps:1
Hi all, wondering if someone could point me in the right direction with regard to connecting my heat exchanger unit for my shower. I have a 2006 V6 hilux, just want to know which heater hose to tee into. Has anyone fitted a shower system to this modle hilux before. Your help would be awesome.
Reply By: vk1dx - Wednesday, Jul 29, 2009 at 10:36
Hi Kato Kid.
I cannot help you directly other than to suggest you go back to where you purchased it and they may be able to help. What about your local mechanic. That may be one avenue. I do not know the Hilux otherwise I would love to help. If you are in a 4WD club maybe one of the members may help.
Where are you?
AnswerID: 376639
Reply By: Member - Troll 81 (QLD) - Wednesday, Jul 29, 2009 at 10:38
Hey
I have one in my Patrol but I assume they are all very similar. I could take a photo later today and post that if that will help?
I have a twine unit
AnswerID: 376640
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Jul 29, 2009 at 12:00
These pics aren't too good as I don't take delivery of the vehicle untill friday but show where it usually gets installedImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
and the hose fittings for the shower head etc poke out the grill.
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 376652
Reply By: Moose - Wednesday, Jul 29, 2009 at 13:20
Go to the Glind website and download theie instructions. You should be able to adapt them to your brand.
AnswerID: 376661
Follow Up By: Moose - Wednesday, Jul 29, 2009 at 13:21
theie should be their - must remember to spell check!
FollowupID: 644070
Reply By: Member - bungarra (WA) - Wednesday, Jul 29, 2009 at 22:13
you dont actually "T" into any hose. The heat exchanger is fitted INLINE in the heater hose and normally the cold water (external source) is arranged so that the cold flow (what you are using for the shower) is being pumped in the reverse direction to that of the coolant that is flowing through the vehicles hot water system.
easiest way to tell where to connect the exchanger INLINE (if you are unable to follow the water path by looking etc) is to start the engine cold and then have someone open the heater valve so as to commence coolant flow into the cab heater..you should be able to feel the external temperature of the hoses change..the first one hot is flowing into the vehicles heater...put the heat exchanger INLINE to that hose and then connect your cold water flow in the opposite direction
VKS 1341
AnswerID: 376758
