body lift ford courier
Submitted: Monday, Sep 08, 2003 at 18:45
ThreadID: 7111 Views:4242 Replies:2 FollowUps:0
has anyone got any info on how hard it is to do a 2" body lift on a 96 ford courier dual cab
Reply By: Member - Eric- Monday, Sep 08, 2003 at 20:47
does the courier had the same suspension as a Pathfinder ?? if yes check out Australia 4x4 , they lifted one 40 mm Craigs hut 2003
AnswerID: 30495
Reply By: Truckster (Vic) - Monday, Sep 08, 2003 at 23:35
If its the same as other cars, then just undo the bolts holding on the body, and lift it put blocks in place, and longer bolts back in.
Probablky have to extend things like shift levers, and brake lines etc.
Theres a check list for a GQ on a body lift on www.gqpatrol.com gives you an idea of the problems that occur on a GQ, so similar things would happen in yours.
Remember radiator to fan and other major components are out of line when you lift the body....
AnswerID: 30530
