Hand Winch Capacities
Submitted: Wednesday, Sep 10, 2003 at 07:23
ThreadID: 7144 Views:11594 Replies:9 FollowUps:8
Hi folks:
I am looking at purchasing a Hand Winch (brand undecided at present). Would a 1.6 tonne capacity hand winch, used in conjunction with a couple of snatch blocks be adequate for getting my 91 Landcruiser out of most situations?
Many thanks.
JackAustralia - If you don't love it, leave!!!
Reply By: Tony - Wednesday, Sep 10, 2003 at 07:37
In most recovery situations you only need to move the vehicle 1 or 2 lengths of the cable and you can drive out, but the effort involved will be massive.
As for the 1.6 tonne and a couple of snatch blocks doing the job a lot easier I would have to say yes. But you will need a couple of winch ext. straps to make up the distance lost in doubleing up the wire cable through the blocks and you will have a much reduced distance that you can pull before you have to run the cable out again.
AnswerID: 30652
Follow Up By: tim - Wednesday, Sep 10, 2003 at 09:43
I am with you Tony the amount of cable these winches have is not very much and if you use a block as well it would be a pain to keep stopping let more cable out run it around another tree and start again
FollowupID: 21685
Reply By: Member - Cocka - Wednesday, Sep 10, 2003 at 08:26
Each turn of a block increases the capacity by + onc of the capacity of the pulling force. Put another way, if you have one turn through a block ie two lengths of pulling force the capacity is doubled - 1.6+1.6 = 3.2 tonne capacity. Passed through another block is + another 1.6 = 4.8 tonne. You loose a little bit of the advantage by any friction created at the blocks and though it would be easy going it would take forever to lever the cable through 2 blocks. The blocks have a rated capacity also.
Whats the loaded weight of your wagon ? and remember you are not lifting the whole weight, just pulling it along or up certain unknown gradients.
4wd monthly mag just did a review of hand winches in a special edition.
I'd get the best winch first, do a test pull somewhere then try one block if you think you might need it.
AnswerID: 30655
Follow Up By: Member - Bonz (Vic) - Wednesday, Sep 10, 2003 at 21:03
Dead right Cocka, I got a Big Haul 1.6t job at the 4WD show in Melbourne a few years ago and with one block its more than enough to pull along a laden Patrol. The Big Haul even got a good write up in the three winch tests i have read FOLLOWING the purchase - Amazing, I actually bought the one recommended...now to get a recommended snatch strap........So many places to go!
So much work to do :0(
FollowupID: 21731
Reply By: ExplorOz Team - David - Wednesday, Sep 10, 2003 at 10:33
Jack,
We carry a 1.6t hand winch and two blocks + 20mtrs of winch strap and tree trunk protector. In all our time travelling I have had the same setup - Used the winch about 4 times, winch strap 3 times, tree truck 4 times, blocks never.
I think that a hand winch is a far better choice for general touring recovery (than the power winch) as it gives you the advantage that you can pull sideways, backwards as well as forwards. Two of my 4 winch recoveries were to pull our trailers around or back onto it's wheels once. Only twice have I used it to pull the vehicle alone and only once was that forward. Add to this the weight saving and the hand winch is a winner. Get a good unit and you will keep it for years and years - hopefully you will never need it but it is nice to know it is there.
In fact you can see what we carry here - [ View Image]or read more in the Recovery Gear Topic .
Enjoy.
Always working, not enough travelling ;-)
AnswerID: 30658
Reply By: flappan - Wednesday, Sep 10, 2003 at 10:41
I recon a hand winch is one of the best pieces of recovery gear around.
With the effort required to "unstick" yourself, you'll never want to get stuck.
AnswerID: 30659
Follow Up By: Willie - Wednesday, Sep 10, 2003 at 12:18
So true....Hope that Jack is a young fella with lots of energy :-))Never a dull moment
FollowupID: 21692
Follow Up By: Member - Jack - Wednesday, Sep 10, 2003 at 15:50
Nope Willie, Jack is an old bloke with a fair amount of time and patience if he gets stuck. :)
Hopefully I will never need it, but I have the view if I need to get it out, I just get ready to be around in the same place for a time.
FollowupID: 21706
Reply By: Rhubarb - Wednesday, Sep 10, 2003 at 15:45
A 1.6T winch should be able to be used on a heavy 4WD in almost every situation. Remember that the 1.6T is the safe working hoist load of the winch, and any winch worth buying will have a safety factor of 5. This means that the winch can very safely lift 1.6T straight up of the ground. It also means that the breaking point (the way snatch straps are rated) of the winch is 1.6 x 5 = 8T.
Also when winching you are not necessarily pulling the full weight of your 4by. It depends on the rolling friction. For example if your stuck on a flat bit of mud, just because you have lost traction and are not dug in, the rolling friction will be much less than 1.6T. However if you get stuck in it up to chasis on an incline, then the rolling friction will probably be greater than 1.6T and you should use your snatch block.
You shouldn't use more than two snatch blocks unless you really know what your doing, because the forces you are dealing with are very full on.
Where rolling friction is very low (such a train on track on the flat) a 1.6T winch is capable of pulling up to 100T!
As far as brands go personally I would either look at the oringinal Tifor or the Big Haul winch.
Hope this helps and good luck!
AnswerID: 30677
Follow Up By: Tony - Thursday, Sep 11, 2003 at 08:17
You may need to go back to basics on this one Rhubarb, you get a fully loaded Patrol bogged and with diffs sitting on the ground you can double the wieght of the vehicle straight away, now add a bit of an incline ????? your getting very near the shear factor of the safety pins of the winch.
By going back to basics you have to lighten the load on the winch some how.
Dig out in front of the tyres,
jack vehicle and place timber,rocks etc under tyres,
unload all the gear &
build a ramp for the vehicle to run up out of the bog.
This all takes time but what else have you got unless the tide is coming in.
FollowupID: 21751
Follow Up By: Rhubarb - Thursday, Sep 11, 2003 at 11:39
Yes quite right Tony. I was just trying to give an example on how 'rolling friction' affects the load on a winch.
For a better explanation see -
http://www.tractel.com/products/lift&materialshandling/hoists/tirfor/calculation.htm
FollowupID: 21766
Reply By: Truckster (Vic) - Wednesday, Sep 10, 2003 at 17:47
For the cost of a hand winch and all the accessories, go a second hand ELECTRIC winch....
Sit back and press the button and your out!
AnswerID: 30691
Follow Up By: Member - Jack - Wednesday, Sep 10, 2003 at 18:58
Hi Truckster:
Had considered that ... then went looking. Ebay, Trading post, wreckers, local carparks .. (just kidding...) and came up empty. Cost is also a consideration as I only have a pension.
Then there is the other problem that as I am a bit of a mechanical gelding in this area I would not be in a positon to make a proper judgement on whether I was getting a good one or some burnt out thing. So ... I am pretty comfortable with a hand winch.
I don't go looking for trouble on the road, usually because I am travelling solo, but thought if I did get stuck a hand winch will get me out of strife, even if it does take some time.
I have done the recovery thing with my 4WD club, so I am not uncomfortable with hooking the stuff up.
FollowupID: 21718
Follow Up By: Truckster (Vic) - Wednesday, Sep 10, 2003 at 21:21
You can pick up good second hand electic winches for under a grand, which is cheap, hand winch with all the goodies, is around 600+
www.brawn4x4.com (.au?) Colin there, he sells new ones for $1400ish. Brilliant units too.
Specially if you are sick or injured and your wife has to do the recovery... trying to winch in 38degree heat no shade isnt a good thing to have to do.
Just a thought.
FollowupID: 21734
Reply By: bob - Wednesday, Sep 10, 2003 at 20:25
Jack
The mean green hand winch from opposite lock. It is rated at 1.6 tonnes for lifting and 2.5 tonnes for pulling.
AnswerID: 30717
Reply By: Rob from Cairns Offroad Training & Tours - Friday, Sep 12, 2003 at 18:35
In answer to your origional question, yes more than adequate. When you weigh up the versatility, cost, maintenance, weight over the front of your vehicle, it really is hard to go past a hand winch. I have had mine over 20 years and it has never let me down and I have used it in many instances where a vehicle mounted winch couldn't be used. At $350 for a tuff pull I reckon they work out to be nearly 10 times cheaper than an electric winch by the time you have it fitted and if you drive sensibly you may never have to use it. Even tho I have a hydraulic winch fitted I never go anywhere without my hand winch and if I had to choose only one it would definitly be the hand winch. Cheers,
Rob Berrill
90 GXL 80 Series, White, 1HZ, manual,
DTS Turbo, Goodyear MTRs 32\11.50\15,
Gabriel Coils, XGS Series 2000 Shocks
GME3200 UHF, TJM Steel B\Bar, Hella 4000,
OE R\Rack, Ox 10,000lb Hydraulic winch
www.4wdtraining.com
www.cedarparkresort.com.au
AnswerID: 30894
Reply By: Member - Jack - Friday, Sep 12, 2003 at 19:40
Thanks for all your input and advice, folks. Sometimes you just get lucky - I got onto a "Big Haul" 1.6 tonne winch, never used, still in the box, for $200. My lucky day!!!!
Owner has just bought a brand new Landcruiser and got himself an electric winch and had no further need for this one.
Thanks again.
AnswerID: 30900
