Site Search
Section Image
load on roof racks
Submitted: Tuesday, Feb 05, 2002 at 00:00
Thomas
We are planning a 6 months trip mostly through WA's various deserts this year. Despite having a long range fuel tank we need additional fuel in jerry cans on the roof. As we have never travelled with a roof rack before (were lucky enough to fit everything into the car), we have no idea about loading capacities of roof racks (steel) and would like to know about experiences other people had. We have a 80 Series LandCruiser.
Advertisement
ThreadID: 721 Replies: 7
Views: 709 FollowUps: None
AnswerID: 1966   Submitted: Tuesday, Feb 05, 2002 at 00:00
Mike replied:
Thomas, if there is nowhere else to put it, then that's where it has to go. As you use fuel, empty your jerry cans into your tank, so the weight is up there for the shortest time. Your rack must also be in top condition. As for the extra weight on top, adjust your driving to suit. Happy trails, Mike.
Reply 1 of 7
AnswerID: 1975   Submitted: Tuesday, Feb 05, 2002 at 00:00
Kim McFarland replied:
I crossed the Simpson Desert last year with three jerry cans on the roof and although I didn't experience any breakage, the rack did move about 50mm from it's original position. I did have problems with expanding jerry cans (through the heat) and had to regularly vent them. Check your owners manual. The maximum weight that can be loaded on the roof is usually listed there.
Reply 2 of 7
AnswerID: 1976   Submitted: Tuesday, Feb 05, 2002 at 00:00
Reply 3 of 7
AnswerID: 1980   Submitted: Tuesday, Feb 05, 2002 at 00:00
Colin Johnson replied:
try leaving some stuff behind first - there ia lot of 'rocking and rolling' crossing sand dunes !full jerry cans on the roof is a last resort. I used a rack on my '91 'L' Subaru for a CSR trip last year but it had 6 foot supports and it only carried a spare wheel, camp table and a tent. I carried 2 jerries of water and 2 jerries of fuel strapped to a steel false floor in the middle of the car. PS - all our jerries were left full, in the sun for a week, to make sure they didn't leak !!
Reply 4 of 7
Activities Index
Le Relais Bressan Lunch Trike Ride for 2 Le Relais Bressan Lunch Trike Ride for 2
Sunshine Coast - QLD
Imagine riding on a Harley Davidson trike through the quaint villages and lush rolling hills of the
Chocolate Sweet Sunday Walking Tour Chocolate Sweet Sunday Walking Tour
Sydney - NSW
Join us on the sweetest trail in Sydney and stroll the city centre, indulging in hot chocolate or co
Abseiling & Canyoning Tour Abseiling & Canyoning Tour
Blue Mountains - NSW
Learn to abseil in Katoomba, with fantastic views across to the world famous Three Sisters.
Scenic Flight Kakadu Explorer Scenic Flight Kakadu Explorer
Darwin and the Top End - NT
Viewing Kakadu by air is really the best way to experience this magical wonder.
Book Now - Things To Do
AnswerID: 1982   Submitted: Tuesday, Feb 05, 2002 at 00:00
Michelle - ExplorOz replied:
Thomas, your roof rack should have a load rating. eg. our Rhino Roof Rack on our 80 series is rated to 100kg. Never consider overloading it and the rest of the advice here from other readers is all relevant. One thing to note - the roof rack and load will affect your fuel consumption/economy quite significantly. Another thought is to use the roof rack but to shift the packing and consider putting the 2 extra jerrys (or whatever) on the floor of the vehicle and put lighter, bulky items on the roof rack. That would be safer compromise. Fuel really should be avoided on the roof rack - the extra weight on the roof really throws out the balance and you are more prone to roll overs.
Reply 5 of 7
AnswerID: 1986   Submitted: Wednesday, Feb 06, 2002 at 00:00
John R. replied:
Thomas,
I have travelled with roof racks on different vehicles and carried fuel in jerry cans. Try to keep the weight between the axles, ie. don't put them right at the rear. I generally carried mine near the front of the rack in the middle. I used a sheet of ply and/or cardboard or an old foam sleeping mat to provide some padding. Ensure the rack is secure - I found the racks with full-length gutter supports the best. Some racks/roofs are rated to 75 kg - check your manual and rack supplier's limits.
You can cover the jerries with a silver-coloured tarp to minimise heat. Under no circumstances would I carry fuel inside the vehicle - regardless of type. Hope this helps.
Reply 6 of 7
AnswerID: 1992   Submitted: Wednesday, Feb 06, 2002 at 00:00
Ray replied:
Thomas trhe problem is not the weight that the roofrack will carry but the weight that the brackets can hold under severe braking that sets the limit.There have been many cases of roofracks landing on the bonnett under severe braking. If you have to carry fuel, empty the jerrys as soon as you have space in the tanks for each one
Reply 7 of 7
