AnswerID: 384288 Submitted: Wednesday, Sep 23, 2009 at 08:53
ozjohn0
replied:
I alway drain ours after a trip away, then flush and refill before leaving on the next trip. NOTE: Use only quality 'Food Grade" hose to fill the tank.
Ordinary Garden Hose will give you foul tasting water.
If you can't get rid of the bad smells or taste then you'll need to sterilise your tank. The most common methods are of sterilisation are:
# A cup of household bleach (Non Scented like lemon) to a tank of water.
# A Half packet of Bi carb Soda to a tank of water.
# A Half Bottle of 'Miltons" baby Bottle Sterilisation fluid to a tank of water.
# There are also a few propriety brands of tank cleaning fluids available.
Allow the mix to stand in the tank for a day or two then drain the tank and and refill with fresh water. allow to stand again. Then flush and refill a second time with a Food Grade hose. If this doesn't fix the problem, repeat the process.
Along with most van dealers I've always found bleach does the job quite well.
Good luck.
ozjohn.
Reply 6 of 6
