Hilux rear brakes
Submitted: Wednesday, Sep 17, 2003 at 21:59
Backyard
I have a 95 Hi-lux dual cab deisel with really losy brakes, especially on the rear, with the rear
wheels jacked off the ground and the engine idleing in first gear i can push on the brake pedal as hard as possible, and all that happens is the engine will slow slightly, if i pull the handbrake on the engine will stall.
So far i have new rear drums, linings and wheel cylinders, new master cylinder, have tryed a 2nd hand proportioning valve and flexible brake line and have tied the proportioning rod up to simulate fully loaded vehicle, still no rear brakes. I noticed that this problem has occurred before in the
forum archives but no answer was found, can anyone help
Reply By: Member - Eric- Wednesday, Sep 17, 2003 at 22:26
remember that the rear has only 40 % braking and the front is 60% , this to allow the vehicle to stop withought the rear end locking up . Does the vehicle seem to stop ok on the road ??? do you have a spongy pedal ????when you crack the rear brake line for bleading , do you have pressure??? answer these questions , all we will start eliminating items Craigs hut 2003
31374
Follow Up By: Backyard - Thursday, Sep 18, 2003 at 08:32
The vehicle has never stopped
well since i owned it, does have some pressure when bleeding with plenty of flow.
Brakes pedal is hard, but if i disconnect booster it goes even harder
22320
Follow Up By: Member - Eric- Thursday, Sep 18, 2003 at 11:48
have you checked the vacume that comes out of the manifold ???also check the vacume hose for blockiges , or colapsCraigs hut 2003
22333
Reply By: mrdesmo - Thursday, Sep 18, 2003 at 08:00
Sounds to me like a pinched/squashed brake line, seeing as the handbrake works and everything else is new...if its not pinched, check that it isn't blocked, maybe a previous owner got a resevior full of mud or dirt, and its now in the line. I think
water in the lines would cause corrosion which would certainly block it up. Does it flow easily when you bleed the brakes? Any discolouration of the fluid?
Good luck...
31385
Reply By: Truckster (Vic) - Thursday, Sep 18, 2003 at 18:14
Mate has told me that he fitted slotted rotors on his GQ and its made a world of diffrerence, and the price was right.
Apparently there are 3 different materials they are made of to, with the better of them $100ish each.
Thats my one of my next investments as soon as I find someone who can get them at trade cost!
31447
Follow Up By: diamond(bendigo) - Thursday, Sep 18, 2003 at 19:20
gday mate .
what ill do ill ill price some rotors for you and me but ill also price a bulk buy and we can see what happens.jamieson wild cat
22373
Follow Up By: Truckster (Vic) - Thursday, Sep 18, 2003 at 20:50
u really do want a kiss dont you?
Ask about another 4 ,theres bound to be someone else!
22386
Follow Up By: Member - Eric- Thursday, Sep 18, 2003 at 20:51
add me in for that one , would love to see what they would cost for my 80 series . Just finished overhauling calipers today Craigs hut 2003
22387
Follow Up By: Truckster (Vic) - Friday, Sep 19, 2003 at 23:03
find out about caliper kits too! early 91 mod with single piston calipers..
would also like to find some twin piston ones off later model
22477
Reply By: Jeff (Beddo) - Friday, Sep 19, 2003 at 19:48
Had mates with hiluxs which had problems with sand getting in drums causing them not to work.Cheers, Beddo
Surf KZN185
<- Yengo NP, Central Coast NSW
31535
Reply By: Shaker - Saturday, Sep 20, 2003 at 18:39
Try this .... completely back off the handbrake adjustment, adjust the rear brakes, then re-adjust the handbrake. Worked for me!
31571
