Site Search
Section Image
Anyone tried a GME AE4006 whip on a GE AE4018K1 base?
Submitted: Tuesday, Oct 27, 2009 at 08:40
stark
Article Overview - UHF Radio
If you are considering a trip into Australia’s vast outback, then a UHF Radio is an important communications device to have. View Full Article...
I have recently put a new UHF on my navara and I have got the GME AE 4018K1 antenna. It is a good 4.5db antenna but I was looking to put a 6db one on it for when I am out in the open a little more. It looks like the AE 4006 will fit on the same base.
I have spoken to GME on this and they have confirmed (after a bit of running around) that the AE 4006 whip will fit on the AE 4018K1 base, however it will void any warranty. They say that the base is not designed for that length whip.
I can totally understand their position. They said it may last quite well on that base for 12 months.
For me I would only be putting the larger whip on when I am heading out in the open. Usually only for day trips, but every now and again it will be a longer trip.
I was just wondering if anyone else has interchanged the AE 4006 whip on the AE 4018K1 base? If so, was the range a lot better in the open and have you found any problems with the base not being up to it?
Thanks for your help!
ThreadID: 73335 Replies: 5
Views: 324 FollowUps: 6
Post Reply Thread Watch Back To Forum Alert Moderator FAQ
AnswerID: 388915   Submitted: Tuesday, Oct 27, 2009 at 09:05
Member -Signman replied:
Hiya,
I'm not up to speed with all those numbers, but I assume the AE4018K1 is the 4.5db co-linear with the liitle tube type elevated base ??That whip is about 600mm long ?? And the 6db whip is about 1200mm long with (Ithink) 3 obvious coils on it??
If that is the case the 6db whip is NOT suitable for the 'elevated base' type antenna setup. !! It will dramaticcaly affect the matching with the radio- and will eventually, damage your radio.
The 6db whip can be used on the 'standard' dome type base- so long as it has a good earth plain...
Just my threepence worth !!!!
The Ultimate Hitch-hiker
Click Image to Enlarge
Each morning I seize the day...
but by mid afternoon it has escaped!
Signman- NSW
VKS737 M3364 Selcall3364
Amateur Callsign: VK2EZY
Reply 1 of 5
FollowupID: 656650   Submitted: Tuesday, Oct 27, 2009 at 11:01
trainslux posted:
Hiya Signman.
Could you explain more as to why you cant fit a 6db whip to replace the 4.5db whip??
I was under the understanding that you could with no ill effect.
Just want to see why, not questioning your tec experience level or anything like that, would just like to learn why.
Trains
FollowUp 1 of 3
FollowupID: 656653   Submitted: Tuesday, Oct 27, 2009 at 11:25
stark posted:
Hi Signman, thanks for your reply.
GME said nothing about it affecting the radio, they were just concerned with the extra length on the antenna.
The details of the antenna is as follows;
This is the link to the AE 4018K1 - http://www.gme.net.au/products/antennas/land-477-mhz/AE4018K1
This is the link to the AE 4006 http://www.gme.net.au/products/antennas/land-477-mhz/AE4006
They are both fibreglass whips.
FollowUp 2 of 3
FollowupID: 656662   Submitted: Tuesday, Oct 27, 2009 at 12:00
Member -Signman posted:
Hiya Trains,
I must have hit the wrong REPLY button...see below !!
Signman- NSW
FollowUp 3 of 3
AnswerID: 388938   Submitted: Tuesday, Oct 27, 2009 at 11:30
Sir Kev & Darkie replied:
The AE4018K1 is a Ground Independent system where as the AE 4006 is a Ground Dependent system therefore they are NOT compatible IMO
Cheers Kev
The Pyrenees
I am NOW living in Chinchilla, the Australian Melon Capital ;)
Reply 2 of 5
FollowupID: 656663   Submitted: Tuesday, Oct 27, 2009 at 12:03
Geez Kev-
you answered in a one liner..that took me 1/2 a page !!!!!
Signman- NSW
FollowUp 1 of 2
FollowupID: 656669   Submitted: Tuesday, Oct 27, 2009 at 12:34
Sir Kev & Darkie posted:
Just calling it as I see it.
I have had some good chats to GME reps in the past at 4WD Shows and this topic has been discussed with them as I have an AE4018K1 antenna on Darkie.
Cheers Kev
The Pyrenees
FollowUp 2 of 2
AnswerID: 388941   Submitted: Tuesday, Oct 27, 2009 at 11:49
The co-linear whip (the one about 600mm long) when mounted on a ground plane only is rated at about 4.5db.
When that whip is mounted onto the ground independant raised feed, that 'assembly' will yield about 6.5db gain. The ground independant 'tube' is made to match the 4.5db whip and give the correct impedance to the transceiver.
Yes, it is mechanically possible to mount the 6db multi-element whip (the one about 1200mm long) onto the ground independant base- but it will not provide a suitable SWR to the radio- and more than likely will damage the radio in the long term. And will not necessarily be that much more efficient.
The 6db whip is better mounted on a good ground plane base only.
That's about as simple as I can describe it !!
Signman- NSW
Reply 3 of 5
AnswerID: 388946   Submitted: Tuesday, Oct 27, 2009 at 12:12
stark replied:
Very informative. Thanks guys!
Reply 4 of 5
Activities Index
See Tasmania Attraction Pass - 3 days See Tasmania Attraction Pass - 3 days
Hobart - TAS
Attraction pass for all of Tasmania. Save over $1000 worth of admission fees.
3 Day Great Ocean Road & Grampians Tour 3 Day Great Ocean Road & Grampians Tour
Great Ocean Road - VIC
Experience a true Australian adventure of camping, glowworms, wildlife and spectacular scenery!
Relaxation Massage - 90 minutes Relaxation Massage - 90 minutes
Sydney - NSW
Enjoy one of our signature massages that has been designed to promote general relaxation, improve yo
Rainforestation Nature Experience Rainforestation Nature Experience
Cairns and Tropical North QLD - QLD
Get back to nature with this experience.
Book Now - Things To Do
AnswerID: 388955   Submitted: Tuesday, Oct 27, 2009 at 13:12
trainslux replied:
Thanks chaps.
I too have the ae 4018k1, and was given a 4006 whip later.
Spoke to the gme rep, and was informed that it would be fine to use on the 4.5db base.
I get good performance the way it is, so wont bother with putting the larger whip on when out and about.
T
Reply 5 of 5
FollowupID: 656745   Submitted: Tuesday, Oct 27, 2009 at 19:42
SteveL (WA) posted:
Mobile-one sells almost identical antennas and strongly advises against mounting the 6dB whip on the ground independent base.Mobile One Website
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
