FollowupID: 658627 Submitted:
Tuesday, Nov 10, 2009 at 22:05
ferris posted:
Troy,
Here is the link to their web site.
http://www.pwr.com.au/#/view=home/http://www.pwr.com.au/#/view=home/
They are based out of the
Gold Coast and l found them to be most helpful, but very expensive. Expensive enough to be individually listed on my insurance policy.
The radiator provides about 50% more cooling l believe, and as l said in the original post I've not had a moments trouble since. Before going down this path l explored larger thermo fans etc..., gave all that a way as a learning experience. To me the quality is long remembered after the price was forgotten.
We had quite a few teething problems, and the radiator had to be freighted back a couple of times to be modified to fit properly, and l had to modify the inter cooler mounts to get the radiator in. PWR were very helpful, and although they didn't say so at the time, l suspect l was one of their first customers with this model radiator.
There are other brands on the market, some of which are cheaper. I haven't seen the others but l was most impressed with PWR's build quality.
If you do order one of these radiators, be careful as Mr Nissan most considerately put a couple of different types of radiators in their 4.2 Patrols. Get a spec sheet from PWR and carefully compare their specs with your radiator.
Good Luck/
Ferris
