FollowupID: 657530 Submitted:
Tuesday, Nov 03, 2009 at 06:17
Mandrake's Solar Power posted:
I think what we are getting at is - you are possibly tackling your problem from the middle rather than either end -
Either you put more power into the system or you take less out .. The extra battery is only going to give you 1 day extra - changing lights to LEDs or changing
fridge to a good lower power consumption type will draw less from the existing battery and make it last longer - Alternatively adding an extra panel will put more power into the system and if sufficient would charge your battery as well as running the household electical items ..
Perhaps you could give us some numbers to work with ?
Wattage of the current panels ?
Amphours of battery ?
Current consumption of major electrical items - particularly
fridge and lights ,,
There is a spreadsheet available for download in the members fileswao area
Solar Power Calculator - 2nd one down
Its not the absolute calculator but it will give you a very good guide .
Mandrake
 | Mandrake's Solar Power |
