FollowupID: 657578 Submitted:
Tuesday, Nov 03, 2009 at 14:18
Tenpounder (SA) posted:
Good news, morton01. On my van, I found that the 'normal' wiring via the 7 pin connector was woefully inadequate to meet the needs of the fridge. Our fridge is the habitual Electrolux/
Dometic 3-way, which won't even get out of bed with less than 10 amps current flow. I have ended up, like many others, with a dedicated 12v supply via
Anderson plugs from the vehicle. I have a 20AMP fuse plus a 15AMP auto-resetting circuit breaker in the vehicle. The standard trailer wiring is amazingly under-rated to cope with a 15 AMP load. Have fun with your new rig.
Kind regards
