Site Search
Section Image
Tyre loads when 4wding
Submitted: Wednesday, Nov 04, 2009 at 19:57
nickb
I was just thinking about load ratings on tyres.
As an example, if a tyre has a load rating of 1100kg and your 4WD weighs 3000kg, that means when you are 4wding and the 2 opposite wheels lift off the ground, the 2 tyres still touching the ground are taking a load of 1500kg.
Also, load ratings are at a certain PSI. When offroading, most people let their tyres down, would that the de-rate the load which the tyre can handle?
Would it cause some sort of damage which wouldn't be immediately apparent?
ThreadID: 73529 Replies: 2
Views: 361 FollowUps: None
Post Reply Thread Watch Back To Forum Alert Moderator FAQ
AnswerID: 390018   Submitted: Wednesday, Nov 04, 2009 at 20:29
Robin Miller replied:
Not so much damage Nick , the load raings are really for speed under load.
So when pressures are down for off roading its ok so long as speed is dropped accordingly
Survivor -Top Crossing Hut Trk
Click Image to Enlarge
Robin Miller
Reply 1 of 2
AnswerID: 390048   Submitted: Thursday, Nov 05, 2009 at 07:55
Snowy 3.0iTD replied:
As stated the load ratings apply for the maximum speed rating. As each section of the tyre deforms and then returns to normal as the tyre rotate, a tiny amount of heat is generated. The more it deforms the more heat is generated, and obviously the faster it is rotating the quicker the heat is generated. You reach a point where the heat is generated by the tyres deforming, faster than it is dissipated, the heat builds up to the point where the tyre delaminates and you have a blowout.
Snowy
Reply 2 of 2
 Page Sponsors
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
Phone: 1800 21 21 21
