I typed in "Air Suspension" in the search field and got 18,524 threads to look at. Then I tried typing in "Air+Suspension" and still got the same number of threads.
So, I'm not sure how to narrow down the parameters...(most of the ones I quickly looked at were about air compressors or air conditioning etc.
So, that leads me to starting a new thread.
I am considering junking my coils and fitting a set of AirBagman full
suspension in their place.
Reason???
Well, basically I have had the wind put up me by a kindly gentleman wearing a blue uniform. This occurred last night at a meeting of a 4wd club I am in the process of joining (if they'll have me). The
Police Officer (Paul Bryant) from
Adelaide, did his usual presentation....as he has done to several 4wd clubs and other interested groups. Paul is a member of the patrol4x4
forum, (as am I) but last night was the first time I'd met him.
Paul's presentation was aimed at bringing to people's attention, various factual information relating to modifying their 4x4s (as
well as other cars).
He didn't really tell us anything (as regards my own Patrol) that I didn't already know; with a couple of notable exceptions:
1). In SA (not sure about other states), it was recently made LAW, that you mustn't increase the diameter of the tyres your vehicle has, by more than 1.5% from the largest ones the manufacturer's tyre placard shows as being suitable. In the case of a GU Patrol (
mine is a 2000 model), they were fitted with 265/70R16. Most owners of that model Patrol replace their tyres with 265/75R16 tyres which are (apparently, according to the info Paul presented) 2.6% larger and therefore (technically) illegal. Paul went on to admit that his patrol has 265/75R16 tyres too. NOTE: I just did my own calculation
Site Link which shows the difference is actually 3.29%. Now, my Patrol is shod with 315/75R16, which are apparently 11.57% larger than the 265/70R16. So that's one thing I need to address if I don't want to cop a fine (pun intended) at some stage down the track.
2). Internal mirror..... I have a dual cab with a canopy that has no windows. Having no visual access out the back, I have removed my internal mirror and replaced it with a rear view camera. Apparently, it is illegal to drive a vehicle that does not have an internal mirror, even though it may be totally useless. NOTE: I will not be refitting the standard mirror....but I may buy and fit the smallest mirror I can find up beside the screen.
Other things noted are lift of more than 2" can be done, but must be engineered....this can cost upwards of $4,000-. A 2" lift is okay without engineering. I already knew this, but as
mine has a 4" lift which has not been engineered for SA, I am considering fitting full airbag
suspension. As I understand it, these can be adjusted (on the fly). So, I would be able to pump them up when I need to have more ground clearance under the body, but keep them at about 2" above standard when I'm on the road and subject to possible
Police scrutiny.
So, after all that verbal diahreare (I know this is spelt wrong, but spell
check couldn't give me any better suggestions), my question is does anybody have a GU Patrol with full air bag
suspension. Please note: I'm not talking about Polyairs or Coil-Rights (which just slip inside the coil spring and help with heavy loads).
Of course, the other big issue that affects more 4x4 owners than anything else, is weight. You don't have to do much to your rig to be overweight. Paul related some of the horror stories he is aware of where seemingly "normal" 4 wheel drives have been involved in MVAs. If the owner is lucky, he gets away with his insurance company wiping him like a dirty backside. However, if someone is killed or seriously injured, the driver can be charged with negligence....not because of the way he drove (he may have actually been "in the right"), but if the vehicle exceeds the GVM, he could still be charged with manslughter or similar because he was driving an un-roadworthy vehicle (because it was over GVM)....... I've known all this stuff for some time, but when it's put to you by a
Police Officer and he outlines the consequences...
well, lets just say it kind of hit
home in a big way with this little black duck.
Roachie
