AnswerID: 390333 Submitted: Saturday, Nov 07, 2009 at 07:30
Anthony
replied:
Hi Dave,
I bought the same model Prado, the 03 GX diesel manual, about 2.5 years back for $38,000. It was an ex Vic Government 4wd. Then 65,000kms, now 123,000kms. It going great still, as you would hope at that number of kms.
I had our local 4wd guy go over it before the purchase. He did a simple check of the engine compression by driving the 4wd onto a steep slope about 40 degrees with the front proint down, then turned off the engine and left in gear (1st or 2nd ???) with the brake off.
If the engine compression was poor, the theory was that the 4wd would move forward with the engine turning over from the weight of the 4wd on the slope and in gear.
If your GX has the std 6.5inch steel wheel, as mine did, I fitted 17 by 8inch stell rims and 245/70-17
tyres (Cooper STT). With this tyre size,I didn't need to add flares and the tyre diameter is abou 777mm, which is the same as the std GXL tyre dia. So the speedo was spot on still.
I think the GX 03 Prado is great, it doesn't have those plastic flare that fall off after a bit of a bump out 4wding.
Reply 4 of 7
