Site Search
Section Image
Jockey wheel options
Submitted: Sunday, Nov 08, 2009 at 20:53
Darbro74
I have a coromal Magnum 440 camper trailer with a ball weight of 220Kgs, and looking for alternative jockey wheel options. I currently use an 8" solid rubber Jockey Wheel. This is incredibly hard to maneuver on any surface. I had purchased a 10" Pneumatic Tyre, which appeared to fold over on itself once the wheel was engaged. Has anyone used a device that handles this weight load? Any suggestions / advise are greatly appreciated.
Kind regards,
Darbro
ThreadID: 73624 Replies: 3
Views: 443 FollowUps: 2
Post Reply Thread Watch Back To Forum Alert Moderator FAQ
AnswerID: 390555   Submitted: Monday, Nov 09, 2009 at 00:34
Member - Tony S (WA) replied:
I run a Mako Mule with a 8" pneumatic tyre on a ball weight of 210kg with a tyre pressure of 60psi or what ever the max of the tyre is.
Manouvering on brick and concrete it is reasonably easy providing the van is mobile and is fairly hard to pivot when stationary. However have not tried it on a loose surfaces.
Sometimes I feel that I should have gone for the dual tyred version.
Tony
Out from Lake Grace
Click Image to Enlarge
The rig
Reply 1 of 3
AnswerID: 390563   Submitted: Monday, Nov 09, 2009 at 07:40
Willem replied:
Darbro
Here is my solution to Jockey Wheel problems. It makes handling a lot easier.
Twin Jockey Wheels
Twin Jockey Wheels
Karoo Jackal
Willem
There is more than one way to get a rabbit
Reply 2 of 3
FollowupID: 658365   Submitted: Monday, Nov 09, 2009 at 10:59
Darbro74 posted:
Nice...I like your way of thinking - how does this maneuver?? I would have thought the wheels would pivot in different directions making the trailer similar to a disfunctional shopping trolley.....This may be a great solution, thanks again
FollowUp 1 of 2
FollowupID: 658370   Submitted: Monday, Nov 09, 2009 at 12:47
Willem posted:
Well, I make sure that the wheels are facing the same way and nudge the drawbar with my leg and then the trailer moves. The twin set-up is more from a safety point as the swing-away jockey wheels are sometimes loose due to travelling vibrations over corrugations or rough country, or when the trailer is on an uneven surface.
Karoo Jackal
Willem
FollowUp 2 of 2
AnswerID: 390582   Submitted: Monday, Nov 09, 2009 at 10:50
jeep cherokee replied:
I have a Coromal F400 which has a ball weight of 132kg and the van weight is around the 1400kg mark I use a single wheel Mako Mule.On solid surfaces its fine and very easy to move the van around, with however as soon as it gets to gravel it does lose its grip and can become awkward to move. Either way, it is better than the pneumatic wheel that i used to use and less strain on the back.
Reply 3 of 3
