Satellite Dish automatic
Submitted: Monday, Nov 16, 2009 at 19:00
Nashy3
Can any one advise suitable providers brands for a satellite dish that is automatic for a caravan? Live In NSW. Installation fors and against and $ for the above. Know nothing about them thanks Nashy
Reply By: Gone Bush (WA) - Monday, Nov 16, 2009 at 19:15
I had this one installed on my Bushtracker:
SmartSat
It's fully automatic including the skew. It comes with a free-to-air set top box which I haven't activated yet. I have connected my Foxtel box to it and it works fine.
It was expensive ($6500) and I agonised over the cost for some time but I bit the bullet and I'm glad I did.
Image Could Not Be Found
391424
Reply By: Member - Graham H (QLD) - Monday, Nov 16, 2009 at 19:43
There is a model sold by Coast to Coast which I have seen for under $5,000
It has 3 hloes across the top part of the dish with blue and red riims around them MAybe an Oyster brand.
The pros I suppose are no setup time and put away time.
The cons as I see it are If you are in a site with trees in the way u have no options to reposition it.
We were in
Tennant Creek when a flash outfit came in and much tooing and froing with his auto dish.
No signal he said Whats wrong Nothing I said my $500 one is working fine.
Dont know he said cost me $7000 and was told it will work anywhere.
Chop down the tree in front of it or shift I said.
OH does that make a difference DUHHHHHHHHHHHHHHHHHHHHHHH
Money does not endear some with common sense..
They will cut out in a really heavy shower of rain as
well sometimes.
MY cheapy works fine and takes about 10 mins or less to set up
Remember you only get 7 Central ,Imparja SBS and ABC in the east and WIN and GWN and ABC and SBS in the west unless you have a magic card which gets it all
10 and the other HD channels are not on Satellite
Select TV and Foxtel are on the same satellite and by paying your money you can get them as
well
391428
Follow Up By: Tricky Dicky - Tuesday, Nov 17, 2009 at 07:31
Hi Graham
If i was to buy a satellite dish am i able to just put my foxtel card in and search for satellite will it work
Richard
659357
Follow Up By: Member - Graham H (QLD) - Tuesday, Nov 17, 2009 at 11:20
Best ask Gone Bush as he is doing that I dont have Foxtel.
659376
Follow Up By: Gone Bush (WA) - Tuesday, Nov 17, 2009 at 11:32
Richard,
get your sat system supplier to confirm that the LNB is the correct frequency for Foxtel then just connect up your Foxtel box same as at home.
659379
Reply By: Leroy - Tuesday, Nov 17, 2009 at 12:03
$5000-$6500..... bleep !! Some of you guys have got more $$$$ than sense. Takes 5-10 mins to align a dish once you get the knack.
Leroy
391487
Follow Up By: Gone Bush (WA) - Tuesday, Nov 17, 2009 at 12:36
Leroy,
how many hearses have you seen towing trailers???
659386
